New Ventus 2 and Discus Winglets - M&H
Old February 20th 12, 12:51 AM posted to rec.aviation.soaring
Alpha Eight
Default New Ventus 2 and Discus Winglets - M&H
M&H announces NEW WINGLETS for the Ventus2 and Discus. The winglets
are designed by Prof. Mark Maughmer of Penn State University and the
Ventus2 winglets are expected to be available late spring 2012. Discus
winglets expected availability will be announced here later.
This is the link http://www.mandhsoaring.com/Winglets.html
Old February 20th 12, 03:32 AM posted to rec.aviation.soaring
Frank Paynter[_2_]
Monty, Heinz,
Please put me on your list of interested parties. My competition
season has a big gap in July - perfect for a retrofit operation! ;-).
Any idea of the retrofit cost?
Regards,
Frank
This is the linkhttp://www.mandhsoaring.com/Winglets.html
Old February 20th 12, 02:21 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
Discus 1 or 2?
Have you spoken to the factory about getting approval for this mod in
Europe?
Those of us in EASA land are pretty much constrained to using the factory
winglets
Kevin
Old February 20th 12, 05:17 PM posted to rec.aviation.soaring
Dan Marotta
I'm curious - since the image on the link appears to have an outward cant,
does this increase the measured span beyond 15 meters, or is more cut off
the tip during initial installation to account for this?
Or, put differently, while sporting these winglets, can the glider still be
fit between two posts spaced 15 meters apart? Or does anyone care about
that any more?
"Alpha Eight" wrote in message
Old February 20th 12, 06:03 PM posted to rec.aviation.soaring
Tom Kelley
fit between two posts spaced 15 meters apart? *Or does anyone care about
that any more?
This is the linkhttp://www.mandhsoaring.com/Winglets.html- Hide quoted text -
- Show quoted text -
Dan,
At the Worlds their is a scrutneer. He really does go over every
glider before the contest starts. Every glider is scheduled for a 15
minute inspection. Even max. pilot weight, which the placard shows, is
enforced. Here at our USA contests it not looked at that close, YET.
Regards, Tom Kelley.
Old February 20th 12, 08:28 PM posted to rec.aviation.soaring
Chris Nicholas[_2_]
Re canted winglets increasing span: I recall a reported conversation
between a well-known competition pilot (WKCP) and purveyor of
modifications etc., and a competition official (CO), re some new wing
tips.
CO: It exceeds 15m span now.
WKCP: Not when it’s flying – the added dihedral from the wings flexing
reduces it to 15m.
CO: When you show me by flying between two posts 15m apart without
hitting them, I will let you compete with those.
End of conversation.
Chris N.
Old February 20th 12, 08:45 PM posted to rec.aviation.soaring
Tony[_5_]
tips.
reduces it to 15m.
Chris N.
US rules allow you to exceed nominal by 2.5 centimeters in the
unloaded position.
Old February 20th 12, 08:47 PM posted to rec.aviation.soaring
Tom Kelley
tips.
reduces it to 15m.
Chris N.
At the Worlds each glider recieves scrutineering. 15 minutes is
scheduled for each one. Long days for the scrutineer for sure, but he
checks EVERYTHING, even including max. allowable cockpit pilot
weight..............
USA not so except weights, but that could always change. Good story
Chris. Ya, another story was the open glider that showed up to be
scrutineered. He came in fully watered, wing tips almost dragging the
ground. He wanted to be checked for span first, then be weighted
AFTER he dumped down to legal takeoff weight. That didn't go very far
either.
Regards, Tom.
Old February 21st 12, 07:37 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
I can personally verify that Harold Drew, scrutineering at the '65
UK Worlds measured the Standard Class gliders by opening two
hangar doors to marginally over an accurate 15,000mm and
required each glider to be manoeuvred through with wings level.
He made the same reply ('you can fly through the gap of you
prefer') when offered the same excuse.
The Finnish Vasama was significantly over span; the Team
Manager offered the explanation that the glider was so new the
wooden spars were still growing. Firm action with a plane to the
wingtip fairings made it legal, if a little less pretty.
conversation
of
new wing
tips.
WKCP: Not when it=92s flying =96 the added dihedral from the
wings flexing
reduces it to 15m.
apart without
Chris N.
Old February 21st 12, 03:41 PM posted to rec.aviation.soaring
Dan Marotta
Wonderful! Great stories and good information.
"Peter Purdie" wrote in message
.com...
conversation
of
new wing
tips.
wings flexing
reduces it to 15m.
apart without
Chris N.
Ventus C Masak Winglets hans Soaring 6 August 25th 06 08:11 AM
Ventus Winglets Shawn Knickerbocker Soaring 2 August 24th 06 11:24 PM
Discus Winglets Peter F Soaring 8 December 12th 05 04:29 AM
Discus Winglets Kevin Neave Soaring 2 October 15th 03 11:35 AM
Wanted: Ventus C Winglets E.Mertins Soaring 1 October 14th 03 01:15 PM
