Schempp-Hirth 2a/2b cockpit fit vs ASW-20?
Old April 7th 12, 06:18 AM posted to rec.aviation.soaring
Rick Walters[_2_]
Default Schempp-Hirth 2a/2b cockpit fit vs ASW-20?
On Apr 6, 2:30*pm, Three Uniform wrote:
I fly a V2C. I believe that fuselage is identical to a 2B.
I fly recreational long XC in the Sierras, dressed for flying at
freezing point.
I always wear a parachute.
At 5'10" and 155lbs bare, the seating is comfortable, but still not
overly roomy sideways.
My seating is fairly reclined. Head room is more than adequate. Panel
reach is fine, rudder paddles are 2/3 back.
Long XC (+6 hours) is fine with no back aches, but not much room to
move.
Reaching into the back of side pockets is doable with a little bit of
stress.
Filling the front of the side pockets takes away from the room for
your arms.
I removed the cable for the back adjustment to have more space in the
arm area.
Reaching the storage shelf behind the head rest is close to
impossible. I can barely pull a fleece from the back.
I sat in a friend's Discus A and concluded that is was not for me. Too
tight for my comfortable recreational flying requirements.
Maybe acceptable if you want to sacrifice the comfort for a little
less drag for competitive advantage.
(My friend is about same size and achieved top5 OLC score in this
DiscusA, so it is for sure doable)
3U
The Ventus 2c is completely different from the 2b, as are the Discus
2b, 2C. The 2C's are much longer and more comfortable. The 2C's are
the only sailplane I can fly with a backpack parachute. I am 197 cm,
6'-5"+. There is about 3" more legroom in the 2C models. ASW20 and
V2b, Db cockpits are very similar in size.
Rick Walters
Old April 8th 12, 12:08 AM posted to rec.aviation.soaring
Chip Bearden[_2_]
There's only so much you can learn from other pilots' reports of
cockpit size. A friend flew an original Ventus A happily even though
he was only a few inches shorter than my 6' 3". I couldn't even fit
into a Ventus B. The key was that he was long legs/short torso. Glad
to hear the V2c is much longer. I recall Rick Walters' "headrest"
chute he used in his Discus.
Another very important factor is the parachute; all thinpacks are not
created equal. With my relatively long torso height, I need a chute
that's thin behind the shoulders and thick in the lumbar region. Most
thinpacks seem to be evenly thick or the opposite of what I need. The
Softie Wedge model is one exception and allows me to recline more and
thus gain some headroom. As with the cockpit itself, the only way to
really tell for certain is to try it on.
Finally, with some gliders, you can make changes in the cockpit. Quite
a few pilots removed the backrest from the ASW 19/20 to fly more
comfortably. My own ASW 24 was altered at the factory to delete the
backrest, swap the factory instrument panel for an aftermarket one
with higher knee cutouts, and move the pedals forward a few cm. Much
of this could be done by the owner.
Chip Bearden
ASW 24 "JB"
USA
schempp-hirth shk-1 shkdriver Soaring 3 September 5th 08 03:38 AM
FS: Schempp-Hirth Discus A Tim Hanke Soaring 0 February 19th 06 02:16 PM
Schempp-Hirth Mel Dawson Soaring 0 February 15th 06 04:08 PM
4SALE: Schempp-Hirth Ventus B Pat Russette Soaring 0 September 6th 05 03:24 AM
Schempp Hirth or its Representatives... Chris OCallaghan Soaring 11 September 23rd 03 09:28 AM
