....what about older 121.5 ELT's
Old April 27th 12, 04:38 PM posted to rec.aviation.soaring
hretting
Default ....what about older 121.5 ELT's
Good question on the Transponder below this thread which leads me to
ponder.....
any good at all leaving the old ELT in until I switch over to the new
( ya...I know....procrastination(?)) system?
I'm thinking of SPOT....how about SPOT+old ELT, or if I get SPOT,
would a new ELT be necessary.
The pressure is on me big time to come out of my cave and open up some
Mayonase jars buried in the back yard and accept the inevitable....BIG
SCREEN NAVS, SPOT, FLARM, ILLEGAL ARTIFICIAL HORIZONS, GN4.0, INFLIGHT
DATA TRANSFER, IMPOTENCE, CONDOR II......and on and on....
I was just getting the hang of 'cut and paste'.
Time to spend the money.
So...back to the ELT question...seriously
R
Old April 27th 12, 05:17 PM posted to rec.aviation.soaring
Tony[_5_]
ponder.....
R
Your ELT will go off when you crash. Since it is an old one the Satellite will not hear it but since you are a good pilot and don't fly off into the distance without telling anyone, surely someone will report you missing. Then the CAP will start looking for you and especially if you told someone your expected route they will start looking for your ELT.
SPOT is a great tool but it is not a replacement for an ELT, mostly because you have to be alive and semi-conscious to activate it.
Old April 27th 12, 05:59 PM posted to rec.aviation.soaring
Darryl Ramm
ponder.....
R
Uh your ELT *might* go off when you crash. That's one of the large issues of ELTs. With something maybe as poor as 15% correct activation rate in GA aircraft crashes, and possibly worse in gliders I would not rely on an ELT activating and would certainly hope I can reach the ELT and manually activate it if possible (and hopefully have a removable antenna (as some ELTs come with) in case the antenna is damaged, or glider upside down etc.
A SPOT tracker can be appealing for lots of reasons, including that in track mode (how most glider pilots seem to use it) you do *not* need to manually activate it to provide last know position information. While not an instant alert, the 10 minute automatic position reports give a pretty good initial search radius (especially when using flight direction info).
Pilots may want to combine different technologies like SPOT and an ELT or PLB. I choose to fly with both a SPOT and a 406MHz+GPS PLB, I especially like the PLB/SARSAT backup to SPOT and the 121.5 MHz homing beacon that the PLB for final homing by SAR organizations (even if it is lower power than a full ELT).
Darryl
Old April 27th 12, 06:26 PM posted to rec.aviation.soaring
kirk.stant
If you already have a working 121.5 ELT, might as well keep it until it dies or you replace it with a 406 ELT.
SPOT is a really good complement to any ELT, because (if used in tracking mode, which is the logical way to use it) it allows real time monitoring of your flight (wifey loves that), and leaves a trail to follow if you don't show up... Downside of SPOT is that if you smack a mountain, it won't send a "come get me!" message; you have to survive to do that.
Ditto with the fancy 406 + GPS PLBs - they are great if you need rescue - but they are not ELTs; they (just like the SPOT basic service) need to be activated by the survivor to be of any use. But if you go down, it could be a lifesaver!
Best setup (IMHO) is an ELT (preferably a new 406, but 121.5 will do) in the glider, a SPOT (with tracking enabled) in the glider or on your chute, and a 406 GPS PLB securely attached to your parachute harness.
Kirk
66
(I've got the 121.5 ELT and SPOT w/tracking)
Old April 27th 12, 07:40 PM posted to rec.aviation.soaring
John Clear
In article 30263873.0.1335547569413.JavaMail.geo-discussion-forums@pbboj7,
A PLB is just a manually operated ELT/EPIRB.
I carry this one:
http://www.aeromedix.com/ACR-Resqlin...eacon-GPS.html
It is about the size of a cell phone, and I use a cell phone case
to keep it on my belt.
When I was in CAP, we'd call ELTs ballast. When you need it, there
is high failure rate. The 15% activation rate in crashes mentioned
up thread is quite possibly optimistic. A stat I saw was that 99%
of ELT/EPIRB activations were false alarms. Chasing the UPS truck
at 2am is one of the reasons I left CAP.
John
John Clear - http://www.clear-prop.org/
Old April 27th 12, 07:59 PM posted to rec.aviation.soaring
Darryl Ramm
I carry this one:
John
Two different but worrisome stats. 15% or so is the correct activation rate when you need it, i.e. the device activates after a crash (but even if corect for GA I suspect its lower in sailplanes because of the poor/incorrect installations I've seen and the low energy of some glider crashes). The 99% or so is the percent or false activations. Both numbers are very rough but probalby give a reasonable feel of the issues here. The high-false activation rate of ELTs is why a old style 121.5 MHz only ELT signal won't necessarily result in a search -- unless people are reporting you missing and local SAR folks are searching. I expect many of us have seen the CAP folks turn up at a gliderport looking for an old ELT going off in a trailer or some other similar thing, a complete and utter waste of their time.
I encourage folks to use a SPOT and an 406 MHz ELT or PLB. If you already have a 121.5 Mhz ELT and don't want to upgrade, at least know its limitations (including no SARSAT detection and no guarantee of automatic search). With ELT mounting and antenna issues, poor crash activation rates and desire to be able to manually activate with a separate antenna is the glider is upside down/antenna damaged etc. I've decided I'd rather have a SPOT mounted on the glider and a PLB on my parachute (instead of an ELT in the glider). Of course if you can find a way to do a SPOT and both and ELT and PLB...
Darryl
Old April 27th 12, 11:32 PM posted to rec.aviation.soaring
Dan Marotta
I just went to the aeromedix website to investigate. My wife and I are
hikers and I fly over remote areas of New Mexico and Colorado. I just
ordered two of these.
I carry this one:
Old April 28th 12, 03:41 AM posted to rec.aviation.soaring
hretting
Lots of good information, ideas, and my exisiting ELT does have an
activation switch on the panel. I will make upgrading to the 406 with
a panel activation switch a priority and the PLB mentioned above has
my interest. My wife is totally not interested in knowing where I am,
only that my life insurance is sufficent. Can't blame her really.
Still on the fence pondering SPOT.
R
Old April 28th 12, 09:40 AM posted to rec.aviation.soaring
Hagbard Celine
Whenever I've investigated ELT's the stats mentioned above always made
me question their value. I've also found that they seem to fail the
annual test at the avionics shop with distressing frequency. Hopefully
the new 406 units will be better (given how much they cost they damn
well should be!). However, I have noticed with several of them that if
you were to try and install them in accordance with the manufacturers
instructions then the stated ground plane requirement could cause
difficulties on non metal gliders. For example the ACK E-04 which is
supposed to be a direct replacement for the ELT's in my club's gliders
specifies a four foot diameter ground plane for the supplied antenna.
I've never found any stats for it but I also kind of wonder just how
often it happens that a crash occurs which A: leaves the ELT in
functioning condition and B: leaves the pilot alive but too
incapacitated to manually trigger a beacon.
Old April 28th 12, 02:18 PM posted to rec.aviation.soaring
kirk.stant
R
Aside from spousal tracking, SPOT is valuable if you fly XC in areas where you might landout and there may not be any cell phone coverage. With just the basic service, you can send an "I'm OK" or a "I landed out, please come get me, I'm at this location (shown on google maps)". Or "HELP, I'm hurt, send the cavalry!" So think of it as a manually activated ELT with additional functions. Not bad for $150.
And you can use it when hiking, boating, etc., since it's not attached to your glider.
IMO, probably the most valuable bit of equipment in your survival kit.
Kirk
66
ELT's Dick[_3_] Soaring 16 August 29th 11 01:53 PM
ELT's [email protected] Soaring 0 March 16th 05 07:27 PM
ELT's Brad Soaring 3 January 20th 05 06:12 AM
New 406 MHz ELT's Brian GJ Soaring 0 July 5th 04 06:52 PM
ELT's, On Star, etc Tim Shea Soaring 3 November 19th 03 08:13 PM
