Good tip, B. Dan at Softie said the same thing. He also suggested it
because in an emergency we typically revert to learned habit and it one's habit is to take off the parachute every time one gets out of the airplane, there's a risk that person would do the same thing when bailing out. I can certainly understand the logic behind that. Shawn "Byron J. Covey" wrote in message .. . A good habit to get into is to exit the airplane following each flight while still wearing the parachute. You will find that it catches on something until you learn the proper body position for clearance. If you have to exit in an emergency, the learned body position will make it easier, although you certainly will be dealing with additional variables! BJC Formerly S-1S w National 360 "ShawnD2112" wrote in message k... Jay, Was in a similar situation and just this weekend took delivery of a new Sortie seatpack chute. I didn't know anything about parachutes, didn't want to become an expert, so I figured I was not a good candidate for buying a used one. Also I didn't really want to trust my last-chance piece of equipment to something I didn't know the full history on. With a bailout rig, there's no redundant system in case it fails. It cost me $1,500.00 but I felt it was one piece of equipment that was worth not scrimping on. I phoned Softie and spoke to Jim, explained the kind of flying I do and what my knowledge base was (none!). He talked me through all the types of rigs and the things I needed to consider. It took about 3 or 4 calls with various questions and dimensions of myself and the airplane to get sorted what I wanted. I haven't used it yet...wait, let me rephrase that...I haven't worn it yet in the airplane, so I don't know if it all fits in the seat pan and I can get in and out of the airplane with it on, but so far so good. I'd give Softie a call just as a place to start. They were really helpful and down to earth. Good luck whichever way you go! Shawn "Jay Moreland" wrote in message news ![]() I need advice on a pilot emergency chute. I am only a pilot and know nothing about parachutes. I need an emergency parachute because I will be doing aerobatics in a Pitts-like biplane: required by FAA. My weight is #140. The altitude I will be landing if I am unlucky enough to need to use the chute is 5400 feet. I am considering purchasing a used parachute that I would have inspected and re-packed regularly by a professional Master rigger. Is buying a 10 year old parachute like a Security, Softie, Strong...etc going to be significantly less safe than a brand new parachute? (Assuming it checks out as OK by the Master rigger) Is there anything to watch out for? Are there any special tests that I need to have done on a used parachute to know that it is still safe? If the red-line on the aircraft is 180kts, should I worry about the parachute being rated to only 150 knots or should I assume that I will slow down to terminal velocity in an emergency and will only need the 150 knot capability? What other considerations should I think of? |
Of parachutes and things | ShawnD2112 | Aerobatics | 34 | July 21st 04 06:13 PM |
For Auction, Emergency Parachute | JC Cunningham | Aerobatics | 0 | June 16th 04 02:47 PM |
FA: Emergency Parachute | JC Cunningham | Aerobatics | 0 | June 11th 04 09:45 PM |
FS, Emergency parachute | JC | Aerobatics | 0 | March 22nd 04 09:51 PM |
Accelerated spin questions | John Harper | Aerobatics | 7 | August 15th 03 07:08 PM |
