Leave the Bees alone and go to a hardware store and buy a 'Toilet ring seal'. They too are made of wax (plummers wax) and a roll of white 3m electrical tape that come in a round plastic container.
Empty the tape container and put a 1/4 of the wax ring seal in it, mail me the tape. This amount will last a life time, so give the rest to a street begger. S-H gliders have a tool to screw into the valve to pull down as one smears the wax into the seat area thru the gap. With a little practice, minimal is use and any dribblets of water can be stopped with little effort. Every couple of years I clean the seat with a Q-tip and find a spot of wax about the size of a pea will last a racing season. The wax stays good even in the heat. Never had a valve stick close. R |
Great advice! The bee's wax I used was given to me by a friend who received
it when he bought his Mini Nimbus. It probably came from your grandfather's bees... "hretting" wrote in message ... Leave the Bees alone and go to a hardware store and buy a 'Toilet ring seal'. They too are made of wax (plummers wax) and a roll of white 3m electrical tape that come in a round plastic container. Empty the tape container and put a 1/4 of the wax ring seal in it, mail me the tape. This amount will last a life time, so give the rest to a street begger. S-H gliders have a tool to screw into the valve to pull down as one smears the wax into the seat area thru the gap. With a little practice, minimal is use and any dribblets of water can be stopped with little effort. Every couple of years I clean the seat with a Q-tip and find a spot of wax about the size of a pea will last a racing season. The wax stays good even in the heat. Never had a valve stick close. R |
VALVES More is Better | [email protected] | Home Built | 8 | January 13th 09 05:34 PM |
LS8 water valves | Bela[_2_] | Soaring | 3 | June 30th 08 03:48 AM |
Water, water, everywhere, but none for thirsty wings.... | Chris OCallaghan | Soaring | 0 | November 21st 04 03:14 PM |
Schemp Hirth water ballast dump valves | tango4 | Soaring | 14 | September 2nd 04 07:13 PM |
Water dump valve rotary seal | Bill Daniels | Soaring | 6 | May 10th 04 11:02 AM |
