Ventus 3?
Old August 16th 12, 06:03 PM posted to rec.aviation.soaring
Tim Taylor
Default Ventus 3?
Also you need to remember that each glider has strengths and weaknesses. One contest in a certain type of flying does not mean one glider I'd better in all locations.
Historically the ASG has been better in very strong conditions while the V2c is better in weaker conditions. If we all flew at Uvalde everyday then building gliders for that environment only makes sense. That said I can see changes coming in the V2 just from the trickle down of the Quentus.
Old August 16th 12, 09:04 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
One only has to look at the 3 view of the Quintus and it's not hard to imagine the wings shortened at the root end and different tips to suit an 18m ship. The airbrakes are well outboard and possibly wouldn't have to be moved
http://www.schempp-hirth.com/fileadm...OM_02_2012.pdf
Of course it's not that simple but wouldn't be surprised if that was part of Schempp-Hirth's thinking when developing the Quintus. The original Antares in 18m and 20m comes to mind as an example of inner panel manipulation at the wingroot
http://www.lange-aviation.com/htm/en...odynamics.html
Colin
Old August 17th 12, 06:08 AM posted to rec.aviation.soaring
JS
Default Ventus 3?
It's likely there will be a new name for the glider to replace the Ventus 2x.
Note that the Quintus is not called Nimbus 5.
Old August 17th 12, 11:53 AM posted to rec.aviation.soaring
Dave Nadler
Default Ventus 3?
The Quintus wing is an Antares 23 wing. It is built at
Lange in the Antares modular mold, which has different
inboard sections for the 18m, 20m, and 23m wings.
So, there is ALREADY an 18m wing in production for
the "18m version of Quintus" - Its the Antares 18S/18T.
Now we just need to get some top pilots flying them...
Hope that clears up the confusion,
Best Regards, Dave
Old August 17th 12, 01:22 PM posted to rec.aviation.soaring
BruceGreeff
Default Ventus 3?
Not that it makes any difference to the discussion but -
The 2c is already a "v3" in all but name.
Compared to the original 1994 V2 - the current model has:
The profile and planform of the vertical and horisontal stabiliser have
changed, the wing outer panel has been revised. It now comes with
Behringer wheels and a larger cockpit.
So it is a little like your great grandfather's axe that was handed down
to you. Completely original, third handle and second head.
The low speed handling is better, the spin characteristics improved, the
polar flattened, wingloading has increased, etc. - But it is still
called a Ventus 2.
Schempp - appear to have been progressively improving the Ventus rather
than going for model one-upmanship.
That said - the Arcus, Quintus change indicates that the Ventus is due
for a substantial change some time soon.
For lots of reasons it is not a good idea to simply change the root of a
wing though, so I doubt it will be that simple. The big change with the
Lange wing is how it is made, rather than the airfoil.
Bruce
Best Regards, Dave
Bruce Greeff
T59D #1771
Old June 21st 14, 06:43 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Default Ventus 3?
So with Leszno coming up in a month and a surprisingly large number of 2CXA's up for sale, any news about the Ventus 2x successor?
Anybody who knows whether the 18 meter Diana II is anywhere near first flight and/or will fly in Leszno?
Old April 15th 15, 12:45 PM posted to rec.aviation.soaring
Default Ventus 3?
Am Samstag, 21. Juni 2014 19:43:24 UTC+2 schrieb J. Nieuwenhuize:
The Ventus 3 is presneted today in Friedrichshafen on the "AERO".
Check out first picture on Facebook site of SH.
https://www.facebook.com/schempphirt...type=1&theater
FS Ventus 2cx 15/18 SAM AND LEIGH ZIMMERMAN Soaring 0 April 29th 08 02:10 PM
FS: Ventus C James Hamilton Soaring 0 September 13th 06 09:18 PM
Ventus C AD KO Soaring 0 September 29th 05 07:05 PM
Ventus C 17.6 John Shelton Soaring 0 November 18th 04 08:39 PM
FS Ventus C 17.6 John Shelton Soaring 0 November 15th 04 09:10 PM
