YouTube Video of the new Butterfly Vario
Old September 23rd 12, 10:58 PM posted to rec.aviation.soaring
Jim[_32_]
Default YouTube Video of the new Butterfly Vario
On Sunday, September 23, 2012 12:03:13 PM UTC-4, Richard wrote:
On Sunday, September 23, 2012 8:50:55 AM UTC-7, Adrien wrote:
Thanks for the specifics. Do you take advantage of Butterfly calculations in the Ultimate? (i.e. do you feed this latter with Butterfly outputs? such as vario, baro alt, wind) Is the wind in the Butterfly also quickly updated and accurate (as far as one can judge), thanks to all the sensors it has? especially in straight flight
Adrien,
I don't use the butterfly vario data yet, I am waiting for the Data Module from Butterfly. The Butterfly is standalone at this point. I use PowerFlarm - LX1606 - Ultimate Le. The winds calculated with the SeeYou PNA on the Ultimate Le are very similar to the Butterfly Vario. The winds of both in my opinion are quick and accurate. I don't see any significant differences. The buad rate for the PowerFlarm to LX1606 to Ultimate is 38400. I think this is important for wind calculations, but I am not sure. Any baud rate teckies out there?
Richard
www.craggyaero.com
Richard, Do any of the instruments in your panel give current wind direction and velocity while flying straight? Or, are they all requiring circling in thermal drift to calculate wind?
-Jim
Old September 24th 12, 01:11 AM posted to rec.aviation.soaring
Richard[_9_]
On Sunday, September 23, 2012 2:58:47 PM UTC-7, Jim wrote:
On Sunday, September 23, 2012 12:03:13 PM UTC-4, Richard wrote: On Sunday, September 23, 2012 8:50:55 AM UTC-7, Adrien wrote: Thanks for the specifics. Do you take advantage of Butterfly calculations in the Ultimate? (i.e. do you feed this latter with Butterfly outputs? such as vario, baro alt, wind) Is the wind in the Butterfly also quickly updated and accurate (as far as one can judge), thanks to all the sensors it has? especially in straight flight Adrien, I don't use the butterfly vario data yet, I am waiting for the Data Module from Butterfly. The Butterfly is standalone at this point. I use PowerFlarm - LX1606 - Ultimate Le. The winds calculated with the SeeYou PNA on the Ultimate Le are very similar to the Butterfly Vario. The winds of both in my opinion are quick and accurate. I don't see any significant differences. The buad rate for the PowerFlarm to LX1606 to Ultimate is 38400. I think this is important for wind calculations, but I am not sure. Any baud rate teckies out there? Richard www.craggyaero.com Richard, Do any of the instruments in your panel give current wind direction and velocity while flying straight? Or, are they all requiring circling in thermal drift to calculate wind? -Jim
I believe the PowerFlarm, LX Navigation 1606 Ultimate give winds if you make a slight course change. the Butterfly I believe straight because it has a compass. I have not noticed much difference with either set of instruments.
Richard
www.craggyaero.com
Old September 25th 12, 01:07 AM posted to rec.aviation.soaring
Jim[_32_]
Richard
www.craggyaero.com
Thanks. I have a PowerFlarm and it does not give any wind info.
Old September 25th 12, 01:15 AM posted to rec.aviation.soaring
Richard[_9_]
On Monday, September 24, 2012 5:07:03 PM UTC-7, Jim wrote:
On Sunday, September 23, 2012 8:11:36 PM UTC-4, Richard wrote: On Sunday, September 23, 2012 2:58:47 PM UTC-7, Jim wrote: On Sunday, September 23, 2012 12:03:13 PM UTC-4, Richard wrote: On Sunday, September 23, 2012 8:50:55 AM UTC-7, Adrien wrote: Thanks for the specifics. Do you take advantage of Butterfly calculations in the Ultimate? (i.e. do you feed this latter with Butterfly outputs? such as vario, baro alt, wind) Is the wind in the Butterfly also quickly updated and accurate (as far as one can judge), thanks to all the sensors it has? especially in straight flight Adrien, I don't use the butterfly vario data yet, I am waiting for the Data Module from Butterfly. The Butterfly is standalone at this point. I use PowerFlarm - LX1606 - Ultimate Le. The winds calculated with the SeeYou PNA on the Ultimate Le are very similar to the Butterfly Vario. The winds of both in my opinion are quick and accurate. I don't see any significant differences. The buad rate for the PowerFlarm to LX1606 to Ultimate is 38400. I think this is important for wind calculations, but I am not sure. Any baud rate teckies out there? Richard www.craggyaero.com Richard, Do any of the instruments in your panel give current wind direction and velocity while flying straight? Or, are they all requiring circling in thermal drift to calculate wind? -Jim I believe the PowerFlarm, LX Navigation 1606 Ultimate give winds if you make a slight course change. the Butterfly I believe straight because it has a compass. I have not noticed much difference with either set of instruments. Richard www.craggyaero.com Thanks. I have a PowerFlarm and it does not give any wind info.
Jim,
You need a PowerFlarm with a vario like the LX1606 or V7 to get wind information. The PowerFlarm or LX1606 alone will not give winds. PowerFlarm sends GPS & Flarm data in the NMEA streat to the vario the vario adds vario sentences to the stream and you software SeeYou Mobile etc will calculate winds.
The ButterFly varo alone will give winds.
Richard
www.craggyaero.com
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 05:49 AM
Butterfly vario info [email protected] Soaring 1 August 7th 12 10:08 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 04:05 AM
another youtube video Brad[_2_] Soaring 1 January 6th 10 09:56 PM
Another YouTube video [email protected] Soaring 38 August 20th 07 03:57 PM
