The 9A.h batteries I use would have a rated capacity of about 8A.h at a current of 0.8A - that's about ten hours' worth. Dropping the temperature to freezing will drop that to about 7 to 8 hours - still more than you're getting.
Also remember that the current drawn by some devices may increase as the voltage drops. I'd suggest checking your current draw at a range of battery voltages. If your charger's ok, it sounds like your battery isn't. Mike |
Actually it is not 10 hours worth....its about 4 hours worth.
The "rated" 9 AH is rated at .05C or 450 ma. If you run at 800 ma, that's about .1C.....so you don't get half the time, you get way less than half........... Also they rate the batteries as "dead" at 10.5 volts, but for glider equipment, once you get down to 11.5 or so, stuff doesn't work well. Actually anything under 12 volts means time to recharge.....below 10.5 volts and battery damage can occur. For an 800 ma draw, the proper battery would be 16 AH.....this in theory would last 20 hours, and leave you at 10.5 volts.....probably 10 hours to stay above 11.5... Cookie At 03:30 24 September 2012, Mike the Strike wrote: The 9A.h batteries I use would have a rated capacity of about 8A.h at a current of 0.8A - that's about ten hours' worth. Dropping the temperature to freezing will drop that to about 7 to 8 hours - still more than you're getting. Also remember that the current drawn by some devices may increase as the voltage drops. I'd suggest checking your current draw at a range of battery voltages. If your charger's ok, it sounds like your battery isn't. Mike |
On 9/24/2012 8:39 AM, Bob Cook wrote:
Actually it is not 10 hours worth....its about 4 hours worth. The "rated" 9 AH is rated at .05C or 450 ma. If you run at 800 ma, that's about .1C.....so you don't get half the time, you get way less than half........... Also they rate the batteries as "dead" at 10.5 volts, but for glider equipment, once you get down to 11.5 or so, stuff doesn't work well. Actually anything under 12 volts means time to recharge.....below 10.5 volts and battery damage can occur. For an 800 ma draw, the proper battery would be 16 AH.....this in theory would last 20 hours, and leave you at 10.5 volts.....probably 10 hours to stay above 11.5... Hi Cookie - I agree it's a good rule of thumb to use batteries at the 20 hour rate, and I encourage pilots use it; however, it doesn't seem to be the problem. Using a bigger battery is desirable in general, but may be awkward to do in practice. SLA data sheets show a 10% reduction in AH capacity at the 0.1C rate, and if you restrict the voltage drop to 11.5 volts, you lose another 10%. That lowers his 9 AH to 7.2 AH, allowing a nominal 9 hour run time at 800 ma. Since he is getting only 4 hours, something is dramatically wrong. A full charge, then a discharge test at 800 ma can rule out charger/battery problems, and it's easy, so that is where I would start. Also, unless you have old "stuff", 11.5 volts is plenty of voltage to run things, and he didn't mention any problems. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
If I am reading the data sheet correctly, I see a lot more than a 10%
reduction in AH at the .1C rate...more like 50% Cookie At 17:41 24 September 2012, Eric Greenwell wrote: On 9/24/2012 8:39 AM, Bob Cook wrote: Actually it is not 10 hours worth....its about 4 hours worth. The "rated" 9 AH is rated at .05C or 450 ma. If you run at 800 ma, that's about .1C.....so you don't get half the time, you get way less than half........... Also they rate the batteries as "dead" at 10.5 volts, but for glider equipment, once you get down to 11.5 or so, stuff doesn't work well. Actually anything under 12 volts means time to recharge.....below 10.5 volts and battery damage can occur. For an 800 ma draw, the proper battery would be 16 AH.....this in theory would last 20 hours, and leave you at 10.5 volts.....probably 10 hours to stay above 11.5... Hi Cookie - I agree it's a good rule of thumb to use batteries at the 20 hour rate, and I encourage pilots use it; however, it doesn't seem to be the problem. Using a bigger battery is desirable in general, but may be awkward to do in practice. SLA data sheets show a 10% reduction in AH capacity at the 0.1C rate, and if you restrict the voltage drop to 11.5 volts, you lose another 10%. That lowers his 9 AH to 7.2 AH, allowing a nominal 9 hour run time at 800 ma. Since he is getting only 4 hours, something is dramatically wrong. A full charge, then a discharge test at 800 ma can rule out charger/battery problems, and it's easy, so that is where I would start. Also, unless you have old "stuff", 11.5 volts is plenty of voltage to run things, and he didn't mention any problems. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Sep 24, 6:45*pm, Bob Cook wrote:
If I am reading the data sheet correctly, I see a lot more than a 10% reduction in AH at the .1C rate...more like 50% Ctrl-C/Ctrl-V: Nominal Capacity 20-hr. (450mA to 10.50 volts) .................................................. ..... 9.00 AH 10-hr. (810mA to 10.50 volts) .................................................. ....... 8.10 AH B. |
http://www.power-sonic.com/images/po...hManual-Lo.pdf
See page 8..... Chart for certain temp. and new battery...Colder or older will net worse time. You really want to stay in the "over 12 volt" range of this chart. Again... 9 AH rated battery is kind of borderline for glider flying at 800 Ma draw.... Solution = larger battery or second battery. Cookie At 01:50 25 September 2012, Bart wrote: On Sep 24, 6:45=A0pm, Bob Cook wrote: If I am reading the data sheet correctly, I see a lot more than a 10% reduction in AH at the .1C rate...more like 50% Ctrl-C/Ctrl-V: Nominal Capacity 20-hr. (450mA to 10.50 volts) .................................................. ..... 9.00 AH 10-hr. (810mA to 10.50 volts) .................................................. ....... 8.10 AH B. |
On Sep 25, 4:15*am, Bob Cook wrote:
On Sep 24, 6:45=A0pm, Bob Cook *wrote: If I am reading the data sheet correctly, I see a lot more than a 10% reduction in AH at the .1C rate...more like 50% Ctrl-C/Ctrl-V: Nominal Capacity 20-hr. (450mA to 10.50 volts) *................................................. ...... 9.00 AH 10-hr. (810mA to 10.50 volts) *................................................. ........ 8.10 AH http://www.power-sonic.com/images/po...1277751263_201... See page 8..... Chart for certain temp. and new battery...Colder or older will net worse time. Yeah, I still see about 10% reduction in capacity at 0.1C. Where you see the 50% reduction, I have no idea. Unless you thought "reduction in discharge time" but wrote "reduction in AH." Bart |
just rechecked the powersonic manual....
at .1c a 12 volt battery will drop below 12 volts in about 5 hours...below 11.5 in about 6.........10.5 almost 10 hours Cookie At 17:41 24 September 2012, Eric Greenwell wrote: On 9/24/2012 8:39 AM, Bob Cook wrote: Actually it is not 10 hours worth....its about 4 hours worth. The "rated" 9 AH is rated at .05C or 450 ma. If you run at 800 ma, that's about .1C.....so you don't get half the time, you get way less than half........... Also they rate the batteries as "dead" at 10.5 volts, but for glider equipment, once you get down to 11.5 or so, stuff doesn't work well. Actually anything under 12 volts means time to recharge.....below 10.5 volts and battery damage can occur. For an 800 ma draw, the proper battery would be 16 AH.....this in theory would last 20 hours, and leave you at 10.5 volts.....probably 10 hours to stay above 11.5... Hi Cookie - I agree it's a good rule of thumb to use batteries at the 20 hour rate, and I encourage pilots use it; however, it doesn't seem to be the problem. Using a bigger battery is desirable in general, but may be awkward to do in practice. SLA data sheets show a 10% reduction in AH capacity at the 0.1C rate, and if you restrict the voltage drop to 11.5 volts, you lose another 10%. That lowers his 9 AH to 7.2 AH, allowing a nominal 9 hour run time at 800 ma. Since he is getting only 4 hours, something is dramatically wrong. A full charge, then a discharge test at 800 ma can rule out charger/battery problems, and it's easy, so that is where I would start. Also, unless you have old "stuff", 11.5 volts is plenty of voltage to run things, and he didn't mention any problems. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Monday, September 24, 2012 11:45:03 AM UTC-4, Cookie wrote:
Actually it is not 10 hours worth....its about 4 hours worth. The "rated" 9 AH is rated at .05C or 450 ma. If you run at 800 ma, that's about .1C.....so you don't get half the time, you get way less than half........... Also they rate the batteries as "dead" at 10.5 volts, but for glider equipment, once you get down to 11.5 or so, stuff doesn't work well. Actually anything under 12 volts means time to recharge.....below 10.5 volts and battery damage can occur. For an 800 ma draw, the proper battery would be 16 AH.....this in theory would last 20 hours, and leave you at 10.5 volts.....probably 10 hours to stay above 11.5... Cookie At 03:30 24 September 2012, Mike the Strike wrote: The 9A.h batteries I use would have a rated capacity of about 8A.h at a current of 0.8A - that's about ten hours' worth. Dropping the temperature to freezing will drop that to about 7 to 8 hours - still more than you're getting. Also remember that the current drawn by some devices may increase as the voltage drops. I'd suggest checking your current draw at a range of battery voltages. If your charger's ok, it sounds like your battery isn't. Mike Cookie nailed it. Also, that is all for a new battery. The numbers all go sour as the battery gets old and abused. Deep discharge is the worst offender over time. Keep 'em charged boys! (Yes even in off-seasons). -Jim |
Battery Power | Mike McCarron[_2_] | Soaring | 13 | September 27th 12 06:22 PM |
battery power regulator | Tony V | Soaring | 17 | August 10th 11 05:39 AM |
Oshkosh Camping - Battery Power | Tom McQuinn | Owning | 3 | June 11th 07 12:19 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
battery charger to get through Piper power port? | Kyler Laird | Owning | 16 | March 20th 05 12:08 AM |
