Capacity flask tube length
Old November 15th 12, 03:11 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
Default Capacity flask tube length
Am 15.11.2012 12:28, dbrunone wrote:
I'm considering relocating my 0.45L capacity flask (for the vario) from
behind the instrument panel to elsewhere in the cockpit. I would have to
use maybe 6 or 7 feet of tubing to do that though...by some quick
calculations, the extra tubing will make the 0.45L flask effectively
almost 0.50L. Would this throw off my vario too much, or will it matter?
Thanks
you could reduce the volume of the flask to compensate, e.g. by putting
an adequately sized block of styrofoam into the flask.
Peter Scholz
ASW24 JE
Old November 15th 12, 05:37 PM posted to rec.aviation.soaring
John Galloway[_1_]
the vario) from
some quick
effectively
or will it matter?
Thanks
e.g. by putting
Peter Scholz
ASW24 JE
If it is a Winter flask I don't think it would be possible to
get the styrofoam in there.
A practical experiment with a 65" length of standard
instrument tubing, a measuring jar and water gives an
internal capacity of 29.7 mls for a 7 foot length. That
would add 6.6% to your capacity so all reading up and
down would be increased by that same amount. A 6 knot
thermal would read 6.4 knots. That wouldn't worry me.
The zero would remain the same. I would be more
concerned about making sure the tubing is fully supported
throughout its length.
John Galloway
Small Sage vario and capacity flask For Sale John Bojack[_2_] Soaring 0 May 4th 09 06:34 PM
Bending brake capacity: 2024-T3 vs. mild steel? Ihab Awad Home Built 2 June 6th 05 10:50 PM
Vario flask insulation Bill Daniels Soaring 37 January 18th 04 01:49 PM
Battery capacity checker Roger Druce Soaring 12 October 24th 03 05:53 PM
Field capacity to repair, overhall, reconstuct, and build airplanes in W.W.I.I. John Freck Military Aviation 32 October 21st 03 07:08 AM
