Battery plugs, etc.
Old December 1st 12, 05:20 AM posted to rec.aviation.soaring
Darryl Ramm
Default Battery plugs, etc.
On Thursday, November 29, 2012 10:51:39 PM UTC-8, wrote:
/snip/
By the way, if you want to see a really interesting mismatch in the audio world facilitated by the use of identical connectors for very different applications you should see how well it works out when someone connects a 1/4" speaker out from a Hiwatt custom 100 to a 1/4" input on a P.A. mixer!
There sadly is something correlated between most musicians and basic electrical knowledge. And yes I've seen guitar amps run into mixing boards, 4x12 guitar cabs trying be run through (low power) instrument cables and folks getting zapped by faulty guitar and mic amp circuits/grounding (and blaming the "phantom power" for that). The last fun was a vintage valve amp catching fire in a friends band...
Darryl
IO-540 prebuy - oil on some plugs [email protected] Owning 5 September 16th 06 03:26 AM
Shields for C-26 plugs Ed Byars Restoration 0 January 23rd 04 08:20 PM
GPS ext power plugs Dave Martindale Piloting 0 September 16th 03 09:26 PM
GPS ext power plugs Dave Martindale Products 0 September 16th 03 09:26 PM
18mm plugs w b evans Home Built 0 September 8th 03 10:43 PM
