Personal flight computers
Old December 9th 12, 04:57 PM posted to rec.aviation.soaring
Roel Baardman
Default Personal flight computers
Admittedly, XC-Soar is extremely flexible and jam-packed with techie goodies but misses the point for cockpit usability (making it useless IMO).
Having never used any software in flight, I am curious about this remark.
I'm wondering if you can elaborate a bit on what you think what the point for cockpit usability roughly is?
Roel
Old December 9th 12, 05:49 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
My personal 'must-have' requirements are that, assuming you entered the
task before taking a launch:
- if its a good day and you complete the task, you shouldn't have had
to touch the system during the flight, i.e. you get task start and
finish notifications, the display zooms in as you approach a turnpoint,
there is a beep and the next TP is selected as soon as you have a point
in the sector and the display zooms out again.
- if you need to skip a TP, abandon the task and head home, or get a
course for the nearest landable field, these should all be doable
without messing about with menus, etc.
- the map shouldn't be cluttered with airspace unless there's a
possibility you'll enter it.
That's my definition and please note that in the UK we seldom if ever
need to change tasks after take-off.
HTH
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 10th 12, 04:11 PM posted to rec.aviation.soaring
So Martin, what is your choice of software?
HTH
org |
Old December 10th 12, 11:31 PM posted to rec.aviation.soaring
LK8000 3.0d.
It does all of the above. By tapping the lettering in the top left corner
of the screen you step through all the TPs in the current task, Home
(which might not be part of the task), the best alternate landout and (I
think) the last thermal.
Functionally I see very little difference between LK8000 and XCSoar (they
have a common ancestor and both run on my Binatone PNA). I use LK8000
because I prefer its display layout to that of XCSoar: I prefer to have
data overlaid onto the map rather than permanently losing screen area to
the infobox array, but of course ymmv.
org |
Question about flight computers Some Other Guy Piloting 0 December 5th 10 12:02 AM
In Flight computers and softwa Walt Connelly Soaring 15 November 21st 10 01:01 AM
Zander 940/941 or ZS-1 Flight Computers??? Tim[_2_] Soaring 8 August 10th 08 10:01 PM
Zander flight computers rhwoody Soaring 0 May 7th 08 04:30 AM
FS slide rule flight computers Military Aviation 0 April 19th 04 03:29 PM
