On Sun, 09 Dec 2012 16:57:39 +0000, Roel Baardman wrote:
I'm wondering if you can elaborate a bit on what you think what the point for cockpit usability roughly is? My personal 'must-have' requirements are that, assuming you entered the task before taking a launch: - if its a good day and you complete the task, you shouldn't have had to touch the system during the flight, i.e. you get task start and finish notifications, the display zooms in as you approach a turnpoint, there is a beep and the next TP is selected as soon as you have a point in the sector and the display zooms out again. - if you need to skip a TP, abandon the task and head home, or get a course for the nearest landable field, these should all be doable without messing about with menus, etc. - the map shouldn't be cluttered with airspace unless there's a possibility you'll enter it. That's my definition and please note that in the UK we seldom if ever need to change tasks after take-off. HTH -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
So Martin, what is your choice of software?
On Sunday, December 9, 2012 12:49:57 PM UTC-5, Martin Gregorie wrote: My personal 'must-have' requirements are that, assuming you entered the task before taking a launch: - if its a good day and you complete the task, you shouldn't have had to touch the system during the flight, i.e. you get task start and finish notifications, the display zooms in as you approach a turnpoint, there is a beep and the next TP is selected as soon as you have a point in the sector and the display zooms out again. - if you need to skip a TP, abandon the task and head home, or get a course for the nearest landable field, these should all be doable without messing about with menus, etc. - the map shouldn't be cluttered with airspace unless there's a possibility you'll enter it. That's my definition and please note that in the UK we seldom if ever need to change tasks after take-off. HTH -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Mon, 10 Dec 2012 08:11:07 -0800, beensoaring wrote:
So Martin, what is your choice of software? LK8000 3.0d. It does all of the above. By tapping the lettering in the top left corner of the screen you step through all the TPs in the current task, Home (which might not be part of the task), the best alternate landout and (I think) the last thermal. Functionally I see very little difference between LK8000 and XCSoar (they have a common ancestor and both run on my Binatone PNA). I use LK8000 because I prefer its display layout to that of XCSoar: I prefer to have data overlaid onto the map rather than permanently losing screen area to the infobox array, but of course ymmv. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Question about flight computers | Some Other Guy | Piloting | 0 | December 5th 10 12:02 AM |
In Flight computers and softwa | Walt Connelly | Soaring | 15 | November 21st 10 01:01 AM |
Zander 940/941 or ZS-1 Flight Computers??? | Tim[_2_] | Soaring | 8 | August 10th 08 10:01 PM |
Zander flight computers | rhwoody | Soaring | 0 | May 7th 08 04:30 AM |
FS slide rule flight computers | Military Aviation | 0 | April 19th 04 03:29 PM |
