![]() Even in the worst cases of conventional bombing (like Tokyo), only 10% of the affected population was killed. It would appear that somewhere between 25 and 30 percent of the Hiroshima population was killed. www.warbirdforum.com/hirodead.htm Comparing kiloton equivalents, it might well be that the Tokyo fire raid was much more devastating. all the best -- Dan Ford email: (requires authentication) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
Cub Driver wrote in message . ..
Even in the worst cases of conventional bombing (like Tokyo), only 10% of the affected population was killed. It would appear that somewhere between 25 and 30 percent of the Hiroshima population was killed. But how many of them were in the area affected by the bomb? |
![]() It would appear that somewhere between 25 and 30 percent of the Hiroshima population was killed. But how many of them were in the area affected by the bomb? But that, surely, is the whole point! The atomic bomb makes rubble bounce. The same or less kilotonnage spread over a wide area might well do much more damage. all the best -- Dan Ford email: (requires authentication) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
It would appear that somewhere between 25 and 30 percent of the Hiroshima population was killed. But how many of them were in the area affected by the bomb? But that, surely, is the whole point! The atomic bomb makes rubble bounce. The same or less kilotonnage spread over a wide area might well do much more damage. To structures, perhaps. But even if we use the lower mortality figures of 7-8% for Tokyo, and 31% for the nukes, there are still a lot more killed within the affected area with nukes. To put it another way, compare the number killed with one of the A-bombs with the number killed in Tokyo. Then compare the area destroyed and the population density of that area. It is true that "people not taking cover from the nukes" is going to skew this some, but I expect that there would still be a considerable difference even if that was taken into account. |
On 22 Mar 2004 06:54:55 -0800, (hiroshima
facts) wrote: To put it another way, compare the number killed with one of the A-bombs with the number killed in Tokyo. Then compare the area destroyed and the population density of that area. No. Compare the kilotonnage per fatality. all the best -- Dan Ford email: (requires authentication) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
On 22 Mar 2004 06:54:55 -0800, (hiroshima facts) wrote: To put it another way, compare the number killed with one of the A-bombs with the number killed in Tokyo. Then compare the area destroyed and the population density of that area. No. Compare the kilotonnage per fatality. Nuclear weapons may well be more costly that way, but you get what you pay for. I don't think there are any instances of conventional weapons killing more than 10% of people in the affected area, and arguments here point to even less than 10%, even for the most deadly use of conventional weapons. However, I have not seen any arguments that have credited the A-bombs with fewer than 30% fatalities in the area affected. By using more explosive per person killed, you also kill a greater portion of the people in the area you are bombing. |
hiroshima facts wrote in message . ..
Nuclear weapons may well be more costly that way, but you get what you pay for. I don't think there are any instances of conventional weapons killing more than 10% of people in the affected area, and arguments here point to even less than 10%, even for the most deadly use of conventional weapons. The trouble yet again is "Affected area" is being defined in a way to increase the perceived lethality of the atomic attacks. Also how many of those conventional attacks were against unwarned populations? Try Pforzheim in 1945 for a very lethal conventional attack. However, I have not seen any arguments that have credited the A-bombs with fewer than 30% fatalities in the area affected. How about we drop the "area affected" for the conventional bombs to something like their known lethal blast area? In which case 90% casualties can be expected, just be within so many feet of the bomb going off. If we ignore anything outside this blast area, since after all there will be only building damage, not destruction, we can make conventional explosives quite lethal. Most of the area is actually "missed" if you use the bomb blast radius. By using more explosive per person killed, you also kill a greater portion of the people in the area you are bombing. There is the overkill factor, since the blast dissipates as the square of distance, the buildings near the centre are hit "too much". Geoffrey Sinclair Remove the nb for email. |
How accurate was B-26 bombing? | ArtKramr | Military Aviation | 59 | March 3rd 04 10:10 PM |
Area bombing is not a dirty word. | ArtKramr | Military Aviation | 82 | February 11th 04 02:10 PM |
WW2 bombing | Bernardz | Military Aviation | 10 | January 14th 04 01:07 PM |
WarPac War Plans-any conventional? | Matt Wiser | Military Aviation | 1 | December 8th 03 09:29 PM |
Looking for Info. on Vietnam Bombing | Seraphim | Military Aviation | 0 | October 19th 03 01:52 AM |
