On Dec 16, 5:42*pm, ProfChrisReed wrote:
You can fit a simple two-way switch to go between average and instantaneous display on the needle (see manual, but it's a 5 minute job). I use my B40 on average pretty much all the time, using the audio for instantaneous readings. Works really well, and if that needle is even a hair above 0 then you're climbing. Does being in average mode change the audio? What is the averaging time? |
On Monday, December 17, 2012 12:42:43 PM UTC-5, soartech wrote:
Does being in average mode change the audio? What is the averaging time? The audio averages over a 1-5 seconds period (running average). Period is factory set to 2 seconds. Adjustment of a pot must be done on the ground with access panel open to change the sample period. The "Average Mode" averages over 20 seconds. There is a momentary contact white push button on the face of the vario. Press the white button and the average is displayed on the dial. I believe that the 20 second average is stored and periodically (say every second) recomputed, so when you press the button, you immediately get the average for the last 20 seconds. The suggested mode is to put a flip switch in parallel with the white button so that the 20 second running average is displayed and continually updated on the analog-like dial. The audio provides the 2 second average. The secondary mechanical vario displays something similar to the 2 second average on the analog dial. The DAD is a numeric LCD that continually displays the 20 second average (the dial would display the 2 second average). |
Borgelt B700 vario | Blake Seese | Soaring | 0 | February 4th 12 06:11 PM |
Used Borgelt B40 Vario. | [email protected] | Soaring | 0 | September 21st 08 05:53 PM |
Wanted: Borgelt B40 Vario | [email protected] | Soaring | 4 | September 16th 08 03:07 AM |
Wanted: Cambridge Vario Display 2 1/4 (57mm) for L-NAV | KO[_2_] | Soaring | 1 | January 14th 08 01:52 PM |
New Borgelt Vario! | [email protected] | Soaring | 2 | June 10th 05 03:45 PM |
