Off season treatment of the Oudie
Old January 9th 13, 06:49 PM posted to rec.aviation.soaring
Ron Gleason
Default Off season treatment of the Oudie
What is the recommendation for storing the Oudie 1/2/Lite during the off season when you are not using it for a number of months?
Let it sit on the shelf?
Plugged into the charger?
Occasionally take if off the shelf and charge it? If so, how often?
Others?
Thanks in advance
Ron Gleason
Old January 9th 13, 07:38 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
Occasionally take if off the shelf and charge it? *If so, how often?
Others?
Thanks in advance
Ron Gleason
On its side, in a cool (55 degrees), dark, moderate humidity,
vibration free place. When checking on it, be careful not to rotate or
shake as it will stir up the 1's that have settled out.
Old January 9th 13, 07:59 PM posted to rec.aviation.soaring
Richard[_9_]
On Wednesday, January 9, 2013 10:49:14 AM UTC-8, Ron Gleason wrote:
What is the recommendation for storing the Oudie 1/2/Lite during the off season when you are not using it for a number of months? Let it sit on the shelf? Plugged into the charger? Occasionally take if off the shelf and charge it? If so, how often? Others? Thanks in advance Ron Gleason
Charge it, makes sure it is off and put it on the shelf. Don't leave plugged into the charger.
Richard
www.craggyaero.com
Old January 9th 13, 08:16 PM posted to rec.aviation.soaring
Ron Gleason
Others?
Thanks in advance
Ron Gleason
Will decanting be required when the soaring season begins?
Old January 9th 13, 09:06 PM posted to rec.aviation.soaring
Others?
Thanks in advance
Ron Gleason
Yes, that will also make room for updated software.
Old January 9th 13, 09:23 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Others?
This is general, not Oudie-specific advice since I've not used an Oudie
and anyway the chances are good that you have other devices with
rechargeable batteries.
LiPoly and Li-ion
================= have very low self-discharge rates, so if the device
has a hard (mechanical) switch, fully charge it and put it away until
next season. Most cheap PNAs (Binatone, Navigon, etc - chepie car sat-
navs) have a mechanical slide switch. OTOH, if it has a soft switch, e.g.
an on/off button witch doesn't click and lacks a mechanical kill switch
like iPAQs had) it will use power even when its off, and so needs a
recharge every month or two. Thats like a laptop computer: shut it down
completely and it can be left for 2-3 months without a recharge, but
suspend it and you'll be lucky if it lasts more than 2-3 weeks without
flattening the battery.
NiCd and NiMH
============= are still found in older instruments and some loggers, e.g.
the EW Microrecorder. These battery types self discharge - a fully
charged NiCd will be almost flat after 6 months and an NiMH self-
discharges 2-3 times faster.
These types should be recharged at least every month or two: EW says the
Microrecorder should be charged every 3 months.
Alternatively, these battery types can be charged continuously at a 1%
rate, i.e. if you're using 1050 mAh NiMH cells (AA size) the 1% rate is
11 mA.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 10th 13, 09:40 AM posted to rec.aviation.soaring
Naviter Info
Richard's advice for Oudie is spot on - It does have a mechanical switch so the advice is to charge it, turn it off (not sleep), put it on a shelf (let it do the magic QT suggests). With any luck it will still be charged when the cumulus reappear.
Andrej Kolar
glider pilots use
http://www.Naviter.com
Others?
LiPoly and Li-ion
NiCd and NiMH
11 mA.
org |
Old January 10th 13, 09:00 PM posted to rec.aviation.soaring
John Carlyle
The Vertica V2 works the same way as the Oudie.
Best paint or treatment for glare reduction? Frank[_1_] Soaring 5 July 19th 07 01:19 AM
ACNE TREATMENT quelab22 Aviation Marketplace 0 January 27th 07 07:42 PM
Anti-corrosion treatment Paul kgyy Owning 1 September 13th 05 04:44 AM
Drug Treatment - Pilot's License Julia Piloting 5 March 18th 04 02:03 AM
