On Fri, 14 Nov 2003 19:12:31 -0600, - Barnyard BOb -
wrote: On 15 Nov 2003 00:22:09 GMT, (JFLEISC) wrote: There's lots of emperical and experiential opinions out there, anybody with some more factual answers to the argument? I've pondered this thing myself. Problem with tail draggers (actually a characteristic of aircraft and their need to have flexible gear way out on spindly aerodynamic legs) is that toe out could change to toe in depending on the load. This also changes during the transition from ground to flight. Worse yet (the big problem with my plane) is the toe change as I bring the tail up on take off or transition down during landing. Suffice to unscientificlly say that 20 years in the automotive alignment business has shown me that cars with toe out tend to be a bit more twitchy than those with toe in. Have no idea if that translates to aircraft because taildragger pilots EXPECT the plane to try to swap ends. Jim +++++++++++++++++++++++ TOE IN is a NO-NO for tail draggers. Just the reverse of cars. And many cars actually DO have a toe out spec. The ideal is for the wheels to roll 100% straight down the road. Depending on steering geometry, they will try to toe out, or in. The spec is to set them toed in if they tend to toe out, and out if they tend to toe in, so that the natural forces pull the wheels towards the straight ahead position. GENERALLY, vehicles with front wheel drive tend to have toe out specs. ( Austin mini (old) was 0.062 inch toe out) - but more and more you are seeing spec of 0 +/-. The position of the tie rod, either ahead of or behind the steering axis had some effect, as does the position of the intersection between the KPI and the wheel centerline (camber). Positive camber contributes to a toe-out tendancy ( that's why cars tend to pull to the side with the most positive camber) (also think about the handling of a bicycle)and Negative caster has the same tendancy. On an aircraft landing gear, the camber is self evident - and the "effective" camber changes with load, and is effected by "unballanced" landings (one wheel first). If the landing gear has "caster" it changes between tail-up and tail-down attitudes. The different combinations of uneven loading and landing attitudes will all effect the "toe" behaviour of the wheel - so it is dangerous to make a statement that either toe out or toe in is NECESSARILY more desirable on a particular plane. Read the archives. This has been beaten to death. Many times. Barnyard BOb - |
On 14 Nov 2003 04:12 PM, - Barnyard BOb - posted the following:
TOE IN is a NO-NO for tail draggers. Just the reverse of cars. One of the instructors at the local A&P school tried to convince me otherwise, unsuccessfully, I might add. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
![]() "- Barnyard BOb -" wrote in message translates to aircraft because taildragger pilots EXPECT the plane to try to swap ends. Jim +++++++++++++++++++++++ TOE IN is a NO-NO for tail draggers. Just the reverse of cars. It depends on whether you have a front or rear wheel drive car, toe-out for front wheel drive and toe-in for rear wheel drive, generally speaking anyway. Just because I can't think of a car with something quite different doesn't mean that it isn't the case, just that I can't think of it.:-)) -- --- Cheers, Jonathan Lowe. / don't bother me with insignificiant nonsence such as spelling, I don't care if it spelt properly / Sometimes I fly and sometimes I just dream about it. :-) Read the archives. This has been beaten to death. Many times. Barnyard BOb - |
toe-out for front wheel drive and toe-in for rear wheel drive, generally speaking anyway. Just because I can't think of a car with something quite different doesn't mean that it isn't the case, just that I can't think of it.:-)) OK, just to add more fuel to the fire. As I said I had 20 years of doing car alignments with repete customers so I got many chances to see "long term" results. If a car "needs" some sort of "preset" (toe in or toe out) to compensate for what will happen when it is driven then experience has tought me that something is generally loose that needs fixing first. Customers want two things; First they want the car to go down the road straight when they take their hands off the wheel. (don't ask me why the hell they are taking their hands off the wheel, I couldn't figure that one out). They also want their tires to wear evenly. End of story. Tried many manufacturer's recommendations over the years but zero toe in always proved the best to keep them happy and coming back. The inner side of the right tire always seems to wear more on my RV. Don't know why and don't care. Rotating them and flipping them on the wheels each odd year gets me 200 hours out of a set. Can't complain; cheap tires and it's the most stable tail dragger I've ever landed. (my tail wheel springs are snug and the wheel is the old non-pivoting type. couldn't tell you if that's good or bad) Jim |
it's that they don't want the car pulling to one side or
the other. Ya think? |
