XCSoar / LK8000
Old March 11th 13, 06:49 PM posted to rec.aviation.soaring
Luke Szczepaniak
Default XCSoar / LK8000
Good points Evan,
From my experience last year, V6.4 was very stable, all rules and
optimizations worked as necessary. As far as the heads down time goes,
I think a lot of that has to do with the pilots setup, I for one barely
touch my Streak in flight, the information I require is on my screen
when needed, automatic thermal mode, automatic final glide mode etc. All
information provided at a glance. Most of the interaction comes in the
form of a swipe across the screen to switch to a different page but only
when necessary, which is rare in my case. Your point about most of the
top guys in the US flying with CN or SN10 is well made, on the other
hand the winner of 2013 WGC Club Class was flying with XCSoar.
http://www.xcsoar.org/discover/2013/...Argentina.html
I'm by no means saying that XCSoar is perfect, but it is constantly
improving, conversely it is part of the problem, new features mean more
bugs and more complexity. While XCSoar is extremely configurable,
configuring it just right can be a daunting process.
Cheers,
Luke Szczepaniak
On 03/11/2013 2:11 PM, Evan Ludeman wrote:
On Monday, March 11, 2013 12:22:15 PM UTC-4, wrote:
On Monday, March 11, 2013 10:13:55 AM UTC-5, waremark wrote:
I would recommend making a fairly quick choice between the software options and putting the time into studying the chosen version. They will all do your job well. If you spend too long choosing you will not only waste time but also end up confused.
So, Max, Paolo or US pilots:
Is either of these two packages useable in a US contest? Do they depict US start, turnpoint and finish definitions, tell you if you're under the top for 2 minutes, help plan time completion for area and mat tasks, compute final glides to a finish cylinder with a minimum altitude, compute final glides around additional turnpoints (mat)? Can you input a task in less than 15 minutes? Is there a quick task A task B option (almost all in air task changes are now A to B)?
I tried xcsoar many years ago. Charlie Spratt changed the task in the air. 15 minutes later on my second reboot, I swore it off. Is contest task entry any easier than back then?
If not, is anyone working on a "US contest" package for either program?
Please no flame wars on how stupid our rules are for using cylinders, 2 minute rules, in air task changes, etc. The rules are what they are. The question is, can this software help a pilot to deal with the rules as they are?
John Cochrane
I spent most of three seasons using XCS for US contests. On Ipaq 3950s to start, later on Dell Streak 5. Nine or ten contests IIRC. Something important was always busted in software. Start rules, AAT task optimizer, little things :-/. I wrote lots of trouble tickets. Some got acted on right away, some never. I haven't used XCS since version 6.3.
There's a timer that can be used to tell you how long you have been under max height.
When things work in XCS, they work well. Task editing is easy on the ground. Task editing in flight depends on your interface, and all of the hardware that I am familiar with that runs XCSoar is touch screen driven. I grew to hate touch screens in flight. My big problem with a touch screen is that I have to look the display for every single poke. This sounds trivial. In fact it adds up to a lot of distraction.
There are better solutions for racing. The two that I am aware of that demonstrably work (i.e. guys win with them, a lot) are SN10 and ClearNav.
The reason that these devices work better is that they take about a quarter the head down time that XCSoar does. Better user interface, easier to read displays in about equal parts. Neither attempts to do nearly as much as XCSoar can, but an awful lot of what XCSoar can do isn't helpful for racing.
The best clues to efficient soaring are outside the window. Less distraction equals better performance in my cockpit, and probably yours too.
By way of disclosure, I work part time for CNi, however this post is my personal opinion, informed by experience.
Evan Ludeman / T8
Old March 11th 13, 07:21 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
That's interesting. The task optimizer -- which worked marvelously well for me in about July of 2011 -- was busted as of late Summer 2011 and I d/l'ed whatever release was current late Summer 2012 (i.e. a year later) just to see if that had been fixed... and found it hadn't. In my case, I always had to enter silly high Mc settings to get reasonable expected XC speeds. I got blown off on that... I guess it wasn't judged to be "serious" :-). The suggestion to add a dirt simple manual override for projected XC speed was likewise rejected.
I agree that figuring out a way to minimize the poking and prodding is a good thing. I liked the visual presentation of the Streak.
Evan Ludeman / T8
Old March 11th 13, 08:10 PM posted to rec.aviation.soaring
Tobias Bieniek
I suppose you are talking about the AAT task optimizer? I've flown two competitions with it last year, and it worked as well as always before... It would be great though if you could point us to the first version that behaved badly for you, because otherwise we can only do wild guesses too.
Old March 11th 13, 10:24 PM posted to rec.aviation.soaring
Kimmo Hytoenen
For me the connectivity of Android based systems is important. I
like to connect with FLARM, variometer and logger. (I am also
dreaming of GPS-NAV communication with XCSoar).
After using Android device going back to Windows CE is not easy.
Mobile communication sends my position into web server, and
maybe I can track my friends online while flying.
User interface is IMHO the problem of all these touch devices.
Simple buttons or rotary switch would be better in turbulence.
For me the most important feature is the moving map and airspace
limits and FLARM traffic view. Then maybe the final glide
calculation. I fly with voice variometer.
Old March 12th 13, 01:57 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
The task calculator, yes.
There was a problem early on in 6.3 that did get sorted out. That problem caused my XC speed predicted vs Mc setting to run very high. I wrote a ticket, it got worked on, many thanks.
Later on, I noticed the inverse: entering for instance Mc 3.0 (knots) would yield an anomalously low predicted XC speed, low 40 mph range. This would have been with what ever version of XCS was current in April/May 2012, 6.3..something. I pulled out my Dell Streak to see if I could reproduce the problem quickly and I cannot, so I withdraw the shot about not being fixed a year later. The version I have loaded is 6.4.5. Mc 3.0 yields 51 mph which is about right if cruising is done in still air for dry ASW-20A, which is the polar I have loaded. Of course we always try to cruise in better than still air, so it's a good thing to be able to tell the nav device that "yes, the next 40 miles are going to be *really* good" due to ridge, cloud street, convergence or what have you. Having to set the Mc value, observe the speed calculated, deciding if it's reasonable, adjusting again maybe and *then* looking at the turn areas to see how far I need to go is a gigantic pain in the ass and an unreasonable waste of time in the cockpit. It's much easier for me to simply estimate speed (based on experience and what I see ahead) and work from this. I find that I can estimate speed quite well for days that go well. On the days that don't go well, I don't care about speed, I just care about getting around and the calculator is of no real import. Anyhow, my $0.02. Sorry I can't shed any illumination on whatever the issue was, perhaps it really is all fixed now.
T8
Old June 30th 13, 12:05 PM posted to rec.aviation.soaring
Having just got into gliding and looking to what software will run, what it offers etc i came across lk8000 and xcsoar, both very good. My first reaction is that two groups of very capable developers have gone separate ways( it doesn't matter why) to develop for the good of glider pilots. Now everyone in life wants different, the world over! Both free, people can download both and sample which they prefer. I personally found lk8000 easier to set up. But haven't used either enough to pick one. As a fixed wing power jock I use skydemon on a mini iPad. I think this suits MY purpose over the others.
With lk8000 and xcsoar you could use both on a tablet pc.
Lets stop the public debate from the developers claiming who has the best! I think it very unprofessional and doesn't affect my judgement as to which I prefer, once I've used both I have no doubt that I will pick one ov er the other.
To the develops, just go out to have in your opinion the best product, don't worry about the competition. The end user will decide on the best. They probably isn't a best as everyone has different ideas on what they require.
Lets all be thankfully that we have a free choice and that people are able to develop software of this complexity and give it away.
From me thanks to both the lk8000 and xcsoar team. Keep up the good work.
Old July 3rd 13, 06:28 PM posted to rec.aviation.soaring
I use a car navigation system, (a Mio Moov, was cheap, like $100 if I recall) and it runs LK8000 great. The display can be a little hard to read in the sun but the new airspace views of LK8000 (both top and side) have been fantastic... our gliderport is underneath the edge of a class B so it's been really helpful to keep track of where I am regarding the airspace above.
Also, clicking through the screens is fast and easy.. the earlier versions of XCSoar (I can't speak for the newest) required clicking tiny little buttons and scroll bars, and thats something that just isn't going to work for me in the cockpit. LK8000 is designed around quick and easy navigation between screens with minimal distraction.. in fact you can identify screens by the sound they make as you switch without looking.
Try both is my advice... read the manuals for both... and watch youtube for examples of how things are done, then test fly them in sim mode or on a simulator.
Old March 12th 13, 03:00 PM posted to rec.aviation.soaring
noel.wade
John Cochrane
John -
I used LK8000 as my only flight computer during the 2012 Montague
Nationals. It works fine for US contests.
There are a few fiddly bits to EVERY flight computer (LK, XCSoar, LX,
Cambridge, SYM - it doesn't matter which one you choose). But LK8000
works fine with US rules and US tasks.
If anyone has questions about how to set up LK8000 for a US contest,
feel free to contact me and I'll be glad to help! (although there
aren't any hard or "secret" settings)
Enjoy,
--Noel
XCSoar or LK8000? Dan Marotta Soaring 18 August 11th 16 02:54 PM
Announcing LK8000 v4.0 pcool Soaring 2 February 16th 13 08:20 PM
Expanding on LK8000 [email protected] Soaring 12 January 23rd 13 06:50 PM
Brief review of Android XCSoar on the Streak 5 and LK8000 on the MIO 400 Mike[_8_] Soaring 7 April 1st 11 10:22 PM
LK8000 questions Andy[_1_] Soaring 9 March 15th 10 11:10 AM
