My Mosquito, back in the 80s, came with an assembly lever like the Libelle.
I have a friend with a Mini Nimbus (same wing) and it has no such capability. When he got the glider, part of the kit was a tire iron with the sharp end dipped in the tool handle rubber stuff to soften it a bit. The theory was to put that through the main pin bushings to pull the wings together. I wonder why Shempp-Hirth copied the wings and not the assembly method. wrote in message ... On Sunday, March 17, 2013 6:56:51 PM UTC-5, Eric Greenwell wrote: On 3/17/2013 4:47 PM, SteveB_Z5 wrote: I agree this kind of tool is useful when one-man rigging, and this Chip, My first 2 gliders both had levers for assembly (Jantar and Libelle) and I can't understand why more manufacturers don't use this method. The tools I make are made from Delrin to be nice to the spar bushings. The tool also protects the bushings from the wear of using the wing pins to bring the bushings into alinement. One would work quite well on your -24. I have used a steel eccentric tool (I like the Delrin idea better), which did a nice job of pulling the wings together; however, my experience on both an ASW 20 C (1500 hours, about 400 riggings) and an ASH 26 E (3400 hours, about 700 riggings), is the wing pins don't wear out the bushings. No discernible wear, in fact. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) Don't underestimate the importance of a good, preferably synthetic grease when assembling any glider. A couple of years ago my tie-down neighbor showed up with his brand-new ASG-29. We just about killed ourselves a couple of times trying to get the heavy inner wings on until I gave him my Super Lube synthetic grease (what a name!). He did have the undersized main pin from Schleicher to align the wings but that still didn't help much. Super Lube to the rescue, don't go to the glider club without it! |
On Monday, March 18, 2013 11:01:42 AM UTC-4, Dan Marotta wrote:
I wonder why Shempp-Hirth copied the wings and not the assembly method. They have "Templins" at the Schempp Hirth Factory, so no problem! T8 |
FS: Eccentric Assembly Tools | SteveB_Z5 | Soaring | 0 | July 27th 12 11:52 PM |
FS: Eccentric Assembly Tools | SteveB_Z5 | Soaring | 0 | January 21st 12 05:37 PM |
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:45 AM |
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:45 AM |
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973447.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:43 AM |
