Portable PowerFlarm hardware update
Old March 21st 13, 07:37 PM posted to rec.aviation.soaring
kd6veb
Default Portable PowerFlarm hardware update
Hi Ramy
One of us is misunderstanding the Flarm operation. Assuming 2 aircraft each with a PowerFlarm and a transponder all powered on they should talk to each other in Flarm language. The PCAS function will be ignored and not displayed. Turn one of the PowerFlarms off and the other will detect the transponder from the plane without the operating PowerFlarm. It will do this in PCAS mode. Then reverse this by switching on the off PowerFlarm and switching off the on PowerFlarm. This will allow you to check the PCAS performance of both PowerFlarms.
So you do need 2 aircraft plus 2 PowerFlarms to perform these tests but because of the criticality of the positional of the antennas I think most people after installing PowerFlarms will want to do these tests with a partner aircraft to check performance.
Dave
Old March 21st 13, 07:49 PM posted to rec.aviation.soaring
Darryl Ramm
Dave
I do not know if the aircraft in your scenario have Mode C or Mode S transponders. For most USA pilots with transponders they will be Mode C and there is no easy way for a PowerFLARM to just "ignore" a Mode C transponder if that aircraft has a PowerFLARM as well. If the other aircraft has a Mode S transponder and the PowerFLARM is correctly configured in that aircraft to also transmit the aircraft's ICAO ID then the receiving PowerFLARM can see the same ICAO ID in bith trabsmissions and has a chance of de-duplicating the target. How well all this works in practice you can try...
Darryl
Old March 21st 13, 11:57 PM posted to rec.aviation.soaring
Ramy
On Thursday, March 21, 2013 11:49:23 AM UTC-7, Darryl Ramm wrote:
Dave
Darryl
Good point Darryl. For mode C it has no way to tell which aircraft transmitting and I know from experience that it will show both flarm and PCAS from that aircraft. However I can't say for mode S if they implemented such filtering or not.
Ramy
Old March 22nd 13, 02:44 AM posted to rec.aviation.soaring
Darryl Ramm
Dave
Darryl
Ramy
I believe so. Try it, you just need somebody with a TT-21/22 and a PowerFLARM.
Of course the ultimate reason to be ablt to see PCAS is to not have transponders interrogated by a SSR radar or TCAS/TCAD source. So Dave/Bumper no running way down low out in the Nevada boondocks when you test for this.
Darryl
Old March 22nd 13, 07:18 PM posted to rec.aviation.soaring
Craig Funston[_2_]
Dave
Darryl
Ramy
Ramy,
How annoying / confusing is it to have both Flarm and PCAS warnings displayed? I'm installing Mode C for this season (not my first choice, but better than nothing) and want to get a feel for whether this will make me unwelcome in the gaggle.
Thanks,
Craig
Old March 22nd 13, 11:44 PM posted to rec.aviation.soaring
Morgan[_2_]
Mode C or Mode S, when flying near a transponder and flarm equipped aircraft you will get both transponder target (the number on the circle) and a Flarm target.
I've seen this many times in the last year. The only real problem with the implementation is that at some point an audio alert was added for when a transponder was within a certain range. Maybe 1 mile??? I have found that to alert at times when thermalling with a transponder equipped glider. It's only a single beep if I remember right. It's been 6+ months now.
I don't find it to be a problem, but certainly is something that could eventually be optimized. I hope that optimizing that behavior is down on their priority list a ways though.
Morgan
Dave
Darryl
Ramy
Ramy,
Thanks,
Craig
When will my portable powerFLARM have its logger functionality? Sean F (F2) Soaring 40 March 18th 13 07:49 PM
powerflarm portable for sale [email protected] Soaring 0 October 23rd 12 04:32 PM
For Sale PowerFLARM Portable (USA) Andy[_1_] Soaring 0 September 17th 12 01:28 AM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 02:50 AM
FS - Powerflarm Portable Westbender Soaring 0 January 9th 12 10:21 PM
