It's very unlikely any instrument is using thermocouples for temperature
sensing; instead, they use standard devices that connect with plain old wire. So, cut the cable, put in the connector, and you are good to go. Be sure the each sensor wire is connected to the same wire from the instrument it was connected to previously. On 5/7/2013 5:44 AM, Paul Remde wrote: Hi John, If I remember my engineering courses correctly, cutting and reconnecting the leads of a temperature probe is not recommended. The temperature sensing depends on the slight difference in the metals in the 2 wires and cutting and especially soldering them together again, or connecting them with metal connectors will change how well they work and will give them an offset. I imagine the LX7000 was calibrated to the sensor at the factory. It would need to be recalibrated if you cut it and solder it together or use connectors. That said, at least one soaring instrument manufacturer is convinced that the temperature sensor is not necessary. They are often installed in locations that lead to very inaccurate readings - such as in the air vent. Those inaccuracies lead to worse information then you would get without a temperature sensor at all. Best Regards, Paul Remde __________________________ "C-FFKQ (42)" wrote in message ... Probably a dumb question... and I think I know the answer... but... May I cut the OAT wires and insert a two-pin connector so that I may place the OAT sensor in a good location in my ship and still easily remove the panel? Looking at the schematics, it's just 2 wires leading to the sensor, so I would think it's okay, but my knowledge of electronics is rather limited (and I'm rather ham-fisted). TIA, John -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Will buy: LX 7000, LX7007 or LX8000 | Erich | Soaring | 0 | December 6th 09 10:54 AM |
LX 7000 igc pro to winpilot | Stuart Kinnear | Soaring | 7 | May 4th 05 02:29 PM |
how to homebrew a 7000-psi mechanical press? | Brian Whatcott | Home Built | 0 | April 23rd 05 07:39 PM |
FS : GPS Trimble TLN 2000 + Moving Map ARGUS 7000 | PA34 F-GFTF | Aviation Marketplace | 0 | January 9th 05 08:42 PM |
Ilec SN 10 or LX 7000 | Dave Kuchenbecker | Soaring | 12 | October 23rd 03 05:05 AM |
