Is the ASW-27B still being made?
Old May 13th 13, 02:25 AM posted to rec.aviation.soaring
SP[_2_]
Default Is the ASW-27B still being made?
On Sunday, May 12, 2013 6:47:37 PM UTC-6, wrote:
Thanks for all the opinions and advice guys!
Rick Lake
Rick, one last thing to follow on to what TK said. Last year I was helping a buddy with some glide testing and we flew a 27 and a 29 in the 15M config side by side. First, I was surprised when we had them next to each other on the ramp you could see a obvious difference in the wings. We ballasted the 27 to the same wing loading as the 29 and towed to 10K and the planes were glued together throughout the entire speed range. This was at a light wing loading. If you can't get the factory to build you a 27 there are plenty of clean used ones around.
Old May 13th 13, 04:51 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Rick Lake
around.
If Rick has the slightest interest in a motorglider, I suggest the used
route. I think the next few years will see some very interesting
motorgliders based on front mounted electric motors (and lighter, more
powerful batteries), plus jet powered self-launching and sustainer
equipped gliders.
For example, Windward Performance is now building at least two jet
powered DuckHawks (aka "JetHawk"). I'm really looking forward to
learning the performance details.
email me)
Old May 14th 13, 04:48 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
At 00:05 12 May 2013, Eric Greenwell wrote:
On 5/11/2013 2:55 PM, K wrote:
On Saturday, May 11, 2013 10:49:47 AM UTC-6, Eric Greenwell wrote:
On 5/11/2013 8:23 AM, Rick Lake wrote:
I've seen conflicting reports, some of which say it's been
replaced
in production by the ASG-29.
It's a 20+ year-old design.
Yes, But it has been updated. Further, It is still competitive. It
beat the Duckhawk at the Nationals. I think you have it backwards;
Find a used DH and order a new 27B .
I have it frontwards: the OP can find and buy a used 27B, but not a used
DuckHawk. He'll have a lot of fun in a great glider while he waits to
see how the DuckHawk, and possibly other new 15 M gliders shake out,
then likely sell it at a good price if he decides to switch.
email me)
So buy a glider designed by Gerhard Waibel or a glider designed by someone
else. I think that is what they call a no brainer. If it starts ASW it's
gonna be right.
Old May 14th 13, 05:35 PM posted to rec.aviation.soaring
equipped gliders.
A bit off topic by now, but what the heck...
It strikes me the right answer for sailplanes is a front electric sustainer powered by a very small battery and fuel cell.
Gliders need light weight. Batteries are all sorts of things but they are not light weight.
Is this to appeal to "green?" Listening to the Antares owners recharge their huge batteries by running loud gas powered generators all night makes a mockery of green. Besides which, the fuel for the motorhome dwarfs what we use for gasoline sustainers.
Gas engines are heavy, and complex to start and operate.
Jet engines are cool, light, and start easily (I gather), but inefficient so you have to carry a lot of fuel. The duckhawk is already suspiciously high wingloading. To say nothing of the FAA's attitude towards experimental jets.
The FES starts instantly, has little drag when extended so needs less power, and if powered by a fuel cell would be really light too.
If fuel cells are impractical, why not a small motor recharging the battery? Then you could have a much smaller battery and motor. You're low, press the switch. The battery fires up and gives you instant power. In a few seconds the motor starts too and you use both battery and electricity from motor and generator for a fast 2000' climb. When the battery is out, engine-generator-motor to sustain or climb slowly. When you shut down, the motor keeps running to recharge the battery. If the motor didnt' start you'd have say 1000' of climb and a few minutes of battery to sort things out for your off field landing.
The energy density of gasoline is hard to beat.
John Cochrane
Still motorless
Old May 14th 13, 06:02 PM posted to rec.aviation.soaring
equipped gliders.
John Cochrane
Still motorless
Cool, the flying Volt! :-)
Old May 15th 13, 12:17 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
landing.
The FES is very attractive, for sure. Windward is also working on one of
those for the SparrowHawk R. They call it "front mounted tractor", since
FES is taken.
I don't know enough about fuel cells to be sure, but I suspect one with
enough power for a good climb of 5 knots might be very expensive. Maybe
have a Li battery for the 2000' of climb, and recharge slowly from a
small fuel cell.
I've wondered if a gas-electric hybrid would be practical. A gas motor
powerful enough to supply half the energy of a 2000' climb at 500 fpm
would be about 20 hp, a fair sized motor. So again, maybe the solution
is a big enough Li battery to do the whole 2000', then use 4 hp motor to
recharge the battery over the next 30 minutes or so.
email me)
Old May 15th 13, 12:58 AM posted to rec.aviation.soaring
landing.
FES is taken.
small fuel cell.
email me)
So, have I done my H.S. physics correctly: a 360kg glider needs about 1hp to
sustain it, given that its normal sink rate is about 1m/s? At that rate your
4hp motor would work really well with enough battery capacity for a 2000' climbout.
Matt
Old May 15th 13, 02:18 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
small fuel cell.
Apparently there was a gas-electric hybrid glider at the AERO
Friedrichshafen show, or at least a poster about one. SoaringCafe has
pictures from the show. One pic is of a diagram of an Albastar 18m
glider with internal gasoline engine driving a generator linked to a FES.
Old May 15th 13, 02:45 PM posted to rec.aviation.soaring
Dan Marotta
"Prius of the Sky"
Real men (and women) fly pure sailplanes.
Just kidding!
"Wallace Berry" wrote in message
small fuel cell.
How Its Made - Ventus 2cx [email protected] Soaring 2 December 22nd 11 06:50 PM
How it's Made - Gliders Craig[_2_] Soaring 15 March 10th 09 12:45 PM
2, People know that Swiss made watches are best, while the Asia madeare worst but cheapest, but Some of Asia made Oyster Perpetual Air King - AllStainless Steel are also close to a real thing that is in fact almostimpossible to tell the difference. [email protected] Piloting 0 April 26th 08 07:49 PM
Made in the USA Lou Home Built 37 August 3rd 06 02:10 PM
The ME 262 is the best plane ever made Rick Stoll Owning 1 May 24th 04 08:23 AM
