APIS motorglider problem
Old May 16th 13, 04:40 AM posted to rec.aviation.soaring
Default APIS motorglider problem
Has anyone with an APIS motorglider had the unfortunate issue of having the cable that connects to the spring loaded prop inter-lock bracket let go, allowing the roller to ride on the flange of the prop hub?
A local APIS has had that very problem and unbeknownst to the pilot the cable or the locking bolt let go and the end result was the roller disintegrating and damage to the flange of the flywheel while the engine was running during a climb out.
Our issue with this damage is two-fold. One is getting parts from the manufacturer, the second is how to release the tension on the drive belt to allow the flywheel to be removed. The maintenance manual offers no hints.
Any help, leads, contacts or spare parts from a damage APIS greatly appreciated.
Thanks
Mike
Old May 17th 13, 02:02 PM posted to rec.aviation.soaring
Sorry to here of your misfortune.
You can contact Pipistrelle who now build the Apis but with a different engine installation. A complete swap may be necessary.
There was a builder in Dallas, Omri Kalinsky who sold his engine parts in favor of installing a jet engine. I don't know if the buyer might still have those parts.
Mark
Apis motorglider key Soaring 15 March 29th 20 05:54 AM
APIS motorglider talwheel [email protected] Soaring 2 October 18th 12 05:25 PM
Apis M pictures Robertmudd1u Soaring 0 February 20th 04 06:40 PM
Apis M has arived Robertmudd1u Soaring 0 January 31st 04 01:50 AM
Apis at Oshkosh Apis Gliders Soaring 0 July 21st 03 03:34 AM
