On Wednesday, July 24, 2013 1:19:52 PM UTC-6, MNLou wrote:
To all - I have assembled two different PW-5's probably a 100 times and have not had the problem you describe. I would guess that something was not aligned? Bill Snead 6W I own a PW-5. Assembling the tailplane has always been a bit "tight" but yesterday, to my frustration, the left tailplane pin refused to be inserted into the left fuselage articulated bearing. The pin would insert to the shoulder and then refused to go further. After much cleaning, greasing, more cleaning, more greasing, lots of sweating (and a bit of swearing), the tailplane finally seated itself. If I had to guess, I think there might have been a burr or grain of sand in the articulated bearing. After flying, dis-assembly was normal. Tight but normal. Has anyone encountered this problem? If so, what was your "fix"? Thanks in advance! Lou (JH) |
On Thursday, July 25, 2013 9:08:58 PM UTC-5, wrote:
Bill Snead wrote - I have assembled two different PW-5's probably a 100 times and have not had the problem you describe. I would guess that something was not aligned? Bill thanks for the response! Everything was aligned enough so that both pins went into the articulated bushings up to the end of the taper on the pin. When the left pin was inserted enough so that the "shoulder" of the pin was being inserted through the bushing, that is when the resistance or binding occurred. If there was some mis-alignment, I couldn't figure it out. I also tried both keeping the tailplane up a bit and keeping it horizontal once the pins were inserted. Neither seemed to do the trick. Might that key an idea? |
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:45 AM |
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:45 AM |
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973449.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:43 AM |
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973447.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:43 AM |
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6522687.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:43 AM |
