This is an attractive aircraft with a lot of room. It also says it can be used as a tow plane ?!?!
Does anyone have any experience with it as a tow plane? |
On Thursday, February 20, 2014 7:55:02 AM UTC-6, Tom (2NO) wrote:
This is an attractive aircraft with a lot of room. It also says it can be used as a tow plane ?!?! Does anyone have any experience with it as a tow plane? We used to have a Lambada that is like an earlier version of the Phoenix, I believe. It was only adequate for towing ultralights and very light gliders such as our PW-5. Visibility towards the rear was very limited. |
On Thursday, February 20, 2014 8:55:02 AM UTC-5, Tom (2NO) wrote:
This is an attractive aircraft with a lot of room. It also says it can be used as a tow plane ?!?! Does anyone have any experience with it as a tow plane? https://www.youtube.com/watch?v=Go8cB8ZxUUI |
Looks like better climb rate than our Super Cub.
I witnessed launches using the 100-HP Samba (cousin to the Lambada) at the 2000 Worlds in South Africa. As I recall, they restricted it to 15-m ships.. With heavy ships at high density-altitude, acceleration and the take-off run appeared long. Climb rates were a bit lower than with more powerful tugs, as you would expect, but seemed to be satisfactory.
This class of aircraft should work fine as a tug at sea level with light gliders, but might be under-powered for launching ballasted ships or two-seaters at higher density-altitudes. Let the experiment be done! Mike |
Question re towplane airworthiness (USA) | Greg Arnold[_3_] | Soaring | 12 | April 20th 10 06:12 PM |
Pik-27 towplane | Brad[_2_] | Soaring | 2 | March 10th 09 12:01 AM |
towplane mirrors | Curt Cole | Soaring | 3 | May 28th 04 02:40 PM |
Towplane Mirror | Thomas J Johnson | Soaring | 1 | May 21st 04 10:36 PM |
Phoenix AIM-54A (QUESTION) | Krztalizer | Naval Aviation | 10 | February 23rd 04 07:22 AM |
