My initial goal was to press home that the FES system (blades, etc) has a significant impact in aerodynamic performance (drag) over the exact same glider without FES I think that it is now clear that a credible study has shown FES performance degradation that is both measurable and significant.
I'm not sure why I should have to fill out a form for action to happen? While there may only be 2 Lak17b FES in the US at current, there are also others in Canada. A re-factored handicap may encourage a few more! Can someone from the handicap committee do the "rough math" (assume 2-4% drag) on the Lak17bFES handicap with a 75 lbs increase weight. Does that result in a handicap? What is the equation or equation set used to create a handicap? Or is it a subjective process? Thanks, Sean |
On Monday, February 24, 2014 12:04:10 PM UTC-6, Sean F (F2) wrote:
My initial goal was to press home that the FES system (blades, etc) has a significant impact in aerodynamic performance (drag) over the exact same glider without FES I think that it is now clear that a credible study has shown FES performance degradation that is both measurable and significant. I'm not sure why I should have to fill out a form for action to happen? While there may only be 2 Lak17b FES in the US at current, there are also others in Canada. A re-factored handicap may encourage a few more! Can someone from the handicap committee do the "rough math" (assume 2-4% drag) on the Lak17bFES handicap with a 75 lbs increase weight. Does that result in a handicap? What is the equation or equation set used to create a handicap? Or is it a subjective process? Thanks, Sean How about if you please relax, take a deep breath, and allow more than three hours between the posting of a link to performance data and publication of a revised handicap number? The drag difference has been presented. There is a standard method applied to correct for weights above initial handicap weight. It is in the rules. Please permit enough time to elpase so that those on the handicap committee at least have a chance to be informed of the data, review it, and provide some sort of comment to the competition committee relative to a change in handicap for this plane, if they believe one is needed. |
On Monday, February 24, 2014 1:04:10 PM UTC-5, Sean F (F2) wrote:
My initial goal was to press home that the FES system (blades, etc) has a significant impact in aerodynamic performance (drag) over the exact same glider without FES I think that it is now clear that a credible study has shown FES performance degradation that is both measurable and significant. I'm not sure why I should have to fill out a form for action to happen? While there may only be 2 Lak17b FES in the US at current, there are also others in Canada. A re-factored handicap may encourage a few more! Can someone from the handicap committee do the "rough math" (assume 2-4% drag) on the Lak17bFES handicap with a 75 lbs increase weight. Does that result in a handicap? What is the equation or equation set used to create a handicap? Or is it a subjective process? Thanks, Sean This is a discussion group that facilitates exchange of information and ideas. It is not in any way a formal part of the competition rules process. If you have a request of the rules or handicap committees you should make that request directly to them. Skewering volunteers in the hope of accomplishing your objective will accomplish nothing. The polar information referenced will be useful in allowing the handicap folks a chance to project expected cross coutry speed and create an appropriate handicap. UH |
I had no intention of skewing volunteers! Just trying to understand the process. Yes I am passionate about the Lak17b FES. I assumed (wrongly) that the HC was a more proactive body.
Social media and even Google Groups seem to be a much easier way to ask questions than emailing. Perhaps the SSA Handicap Committee could consider creating a Google Group or... (hold on to your chairs) even a Facebook group? Social is a much more efficient means of communication and open discussion that email for sure. Facebook groups for example can be private and each member can be approved once credentials are confirmed. Just a thought. Sincerely, Sean On Monday, February 24, 2014 4:00:39 PM UTC-5, wrote: On Monday, February 24, 2014 1:04:10 PM UTC-5, Sean F (F2) wrote: My initial goal was to press home that the FES system (blades, etc) has a significant impact in aerodynamic performance (drag) over the exact same glider without FES I think that it is now clear that a credible study has shown FES performance degradation that is both measurable and significant. I'm not sure why I should have to fill out a form for action to happen? While there may only be 2 Lak17b FES in the US at current, there are also others in Canada. A re-factored handicap may encourage a few more! Can someone from the handicap committee do the "rough math" (assume 2-4% drag) on the Lak17bFES handicap with a 75 lbs increase weight. Does that result in a handicap? What is the equation or equation set used to create a handicap? Or is it a subjective process? Thanks, Sean This is a discussion group that facilitates exchange of information and ideas. It is not in any way a formal part of the competition rules process. If you have a request of the rules or handicap committees you should make that request directly to them. Skewering volunteers in the hope of accomplishing your objective will accomplish nothing. The polar information referenced will be useful in allowing the handicap folks a chance to project expected cross coutry speed and create an appropriate handicap. UH |
Some guidance on the Lak17bFES contest results here (look at 18 meter overall middle of page):
http://www.wgc2012uvalde.us/index.ph...I temid=7#18M My understanding is that these were fairly accomplished pilots. Clearly the FES is not "helping!" On Monday, February 24, 2014 4:40:22 PM UTC-5, Sean F (F2) wrote: I had no intention of skewing volunteers! Just trying to understand the process. Yes I am passionate about the Lak17b FES. I assumed (wrongly) that the HC was a more proactive body. Social media and even Google Groups seem to be a much easier way to ask questions than emailing. Perhaps the SSA Handicap Committee could consider creating a Google Group or... (hold on to your chairs) even a Facebook group? Social is a much more efficient means of communication and open discussion that email for sure. Facebook groups for example can be private and each member can be approved once credentials are confirmed. Just a thought. Sincerely, Sean On Monday, February 24, 2014 4:00:39 PM UTC-5, wrote: On Monday, February 24, 2014 1:04:10 PM UTC-5, Sean F (F2) wrote: My initial goal was to press home that the FES system (blades, etc) has a significant impact in aerodynamic performance (drag) over the exact same glider without FES I think that it is now clear that a credible study has shown FES performance degradation that is both measurable and significant.. I'm not sure why I should have to fill out a form for action to happen? While there may only be 2 Lak17b FES in the US at current, there are also others in Canada. A re-factored handicap may encourage a few more! Can someone from the handicap committee do the "rough math" (assume 2-4% drag) on the Lak17bFES handicap with a 75 lbs increase weight. Does that result in a handicap? What is the equation or equation set used to create a handicap? Or is it a subjective process? Thanks, Sean This is a discussion group that facilitates exchange of information and ideas. It is not in any way a formal part of the competition rules process. If you have a request of the rules or handicap committees you should make that request directly to them. Skewering volunteers in the hope of accomplishing your objective will accomplish nothing. The polar information referenced will be useful in allowing the handicap folks a chance to project expected cross coutry speed and create an appropriate handicap. UH |
Based upon these "results" the handicap of a LAK-17 FES should be 31% lower than an ASG-29. I'm sure we can agree that is not accurate. Perhaps you should do the math before spouting an opinion.
On Monday, February 24, 2014 4:51:33 PM UTC-5, Sean F (F2) wrote: Some guidance on the Lak17bFES contest results here (look at 18 meter overall middle of page): http://www.wgc2012uvalde.us/index.ph...I temid=7#18M My understanding is that these were fairly accomplished pilots. Clearly the FES is not "helping!" On Monday, February 24, 2014 4:40:22 PM UTC-5, Sean F (F2) wrote: I had no intention of skewing volunteers! Just trying to understand the process. Yes I am passionate about the Lak17b FES. I assumed (wrongly) that the HC was a more proactive body. Social media and even Google Groups seem to be a much easier way to ask questions than emailing. Perhaps the SSA Handicap Committee could consider creating a Google Group or... (hold on to your chairs) even a Facebook group? Social is a much more efficient means of communication and open discussion that email for sure. Facebook groups for example can be private and each member can be approved once credentials are confirmed. Just a thought. Sincerely, Sean On Monday, February 24, 2014 4:00:39 PM UTC-5, wrote: On Monday, February 24, 2014 1:04:10 PM UTC-5, Sean F (F2) wrote: My initial goal was to press home that the FES system (blades, etc) has a significant impact in aerodynamic performance (drag) over the exact same glider without FES I think that it is now clear that a credible study has shown FES performance degradation that is both measurable and significant. I'm not sure why I should have to fill out a form for action to happen? While there may only be 2 Lak17b FES in the US at current, there are also others in Canada. A re-factored handicap may encourage a few more! Can someone from the handicap committee do the "rough math" (assume 2-4% drag) on the Lak17bFES handicap with a 75 lbs increase weight. Does that result in a handicap? What is the equation or equation set used to create a handicap? Or is it a subjective process? Thanks, Sean This is a discussion group that facilitates exchange of information and ideas. It is not in any way a formal part of the competition rules process. If you have a request of the rules or handicap committees you should make that request directly to them. Skewering volunteers in the hope of accomplishing your objective will accomplish nothing. The polar information referenced will be useful in allowing the handicap folks a chance to project expected cross coutry speed and create an appropriate handicap. UH |
I had no intention of skewing volunteers! Actually that is exactly what you intended. Since us mere mortals could never live up to your standards, we must be roasted over an opinion fire to make an example of us so know when will question Sean, the god of gliding knowledge! |
On Monday, February 24, 2014 2:41:57 PM UTC-8, Kevin Christner wrote:
On Monday, February 24, 2014 4:40:22 PM UTC-5, Sean F (F2) wrote: I had no intention of skewing volunteers! Actually that is exactly what you intended. Since us mere mortals could never live up to your standards, we must be roasted over an opinion fire to make an example of us so know when will question Sean, the god of gliding knowledge! I am not a competition pilot myself but find it absurd that a glider with FES will get better handicap than one without due to loss of 1 point in glide performance. Surely the advantage of self retrieve outweight 1 point in glide. Otherwise just take the blades off during the contest. Ramy |
I had no intention of skewing volunteers! Just trying to understand the process. Yes I am passionate about the Lak17b FES. I assumed (wrongly) that the HC was a more proactive body. Social media and even Google Groups seem to be a much easier way to ask questions than emailing. Perhaps the SSA Handicap Committee could consider creating a Google Group or... (hold on to your chairs) even a Facebook group? Social is a much more efficient means of communication and open discussion that email for sure. Facebook groups for example can be private and each member can be approved once credentials are confirmed. Just a thought. Sincerely, Sean On Monday, February 24, 2014 4:00:39 PM UTC-5, wrote: On Monday, February 24, 2014 1:04:10 PM UTC-5, Sean F (F2) wrote: My initial goal was to press home that the FES system (blades, etc) has a significant impact in aerodynamic performance (drag) over the exact same glider without FES I think that it is now clear that a credible study has shown FES performance degradation that is both measurable and significant. I'm not sure why I should have to fill out a form for action to happen? While there may only be 2 Lak17b FES in the US at current, there are also others in Canada. A re-factored handicap may encourage a few more! Can someone from the handicap committee do the "rough math" (assume 2-4% drag) on the Lak17bFES handicap with a 75 lbs increase weight. Does that result in a handicap? What is the equation or equation set used to create a handicap? Or is it a subjective process? Thanks, Sean This is a discussion group that facilitates exchange of information and ideas. It is not in any way a formal part of the competition rules process. If you have a request of the rules or handicap committees you should make that request directly to them. Skewering volunteers in the hope of accomplishing your objective will accomplish nothing. The polar information referenced will be useful in allowing the handicap folks a chance to project expected cross coutry speed and create an appropriate handicap. UH If you have input for the RC, or the HC for that matter, the time needed to organize your thoughts and any supporting information is and order of magnitude greater that that needed to do the e-mail itself. If it is not worth taking the time to thoughtfully put the input together, it certainly would not be worth much of their time to consider it. Every e-mail sent to the RC should, and as far as I recall when chair did, get a response and was added to the list of topics to be considered when putting together the annual rules change agenda. UH |
just look at the current handicap boys and girls, which is equal for pure and FES. is that what it needs to be? you tell me HC.
god of soaring? wow, thanks? take a pill there pal. you'll feel better soon. WTH? |
