I can also repair it and change the backup battery and re-seal it.
Best Regards, Paul Remde Cumulus Soaring, Inc. "Peter Purdie" wrote in message ... You are not the first. A SMALL drop of cyanoacrylate glue will hold it when replaced. However, you have to completely disassemble the unit to fix it, after which it will need an agent to electronically reseal (and best to replace the memory battery at the same time). Suggest you ask Gary at Clearnav, who is the US repair agent, or Klaus Keim or Dickie Feakes if in Europe. At 04:14 19 April 2014, Kurt Thams wrote: The needle fell off my 302 today, just sitting behind the plastic bezel. Anyone know how to remove that bezel so I can re-seat the needle? |
I had the same experience a year or two ago and sent the unit to Gary as
suggested and got a quick turn-around. Now I wonder... Since I'm not interested in contests or records and have all my diamonds, couldn't I have simply done the job myself? Wouldn't the unit still provide igc files acceptable to OLC and Skylines? "Paul Remde" wrote in message ... I can also repair it and change the backup battery and re-seal it. Best Regards, Paul Remde Cumulus Soaring, Inc. "Peter Purdie" wrote in message ... You are not the first. A SMALL drop of cyanoacrylate glue will hold it when replaced. However, you have to completely disassemble the unit to fix it, after which it will need an agent to electronically reseal (and best to replace the memory battery at the same time). Suggest you ask Gary at Clearnav, who is the US repair agent, or Klaus Keim or Dickie Feakes if in Europe. At 04:14 19 April 2014, Kurt Thams wrote: The needle fell off my 302 today, just sitting behind the plastic bezel. Anyone know how to remove that bezel so I can re-seat the needle? |
Removing Old Tape | Kevin Christner | Soaring | 5 | March 27th 12 11:07 PM |
Removing RTV | John | Home Built | 6 | October 31st 06 10:07 PM |
Removing Ethanol from Gas? | Jay Honeck | Piloting | 67 | August 16th 06 03:29 PM |
Winter Mech Vario Bezel | Mike Hostage | Soaring | 2 | March 29th 05 05:42 AM |
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 5th 04 11:22 PM |
