On 21 Nov 2003 03:04 PM, Ded Dog posted the following:
Thanks for posts. Just starting out . Have some manuals but none with this information. What would be the gold standard of reference manuals for this information. Had wanted to buy a drill for mostly #30 and 40 drill bits but was at a loss with all the rpm ranges. Sounds like for aluminum I should be looking at a higher rpm range than I originally thought. I had thought this group was amoung other things to use members as a resource. I suppose I shouldn't be suprised that someone should criticize me for asking what to some might be obvious, but I don't think this is a community that eats its young. I might need some more help in the future. KM A brief Google search came up with the following info related to drill speeds: http://www.micoks.net/~dbennett/dpsc.html A Palm application http://www.collinsclubs.com/woodwork...speedchart.pdf A PDF chart, not totally useful since it only goes as high as 3000 rpm ( meant for drill presses) http://www.auto-ware.com/techref/drillspeed.htm A simple chart which only has fractional sizes by sixteenths. http://209.92.149.105/keo/faq.asp Scroll down to the bottom for information which will allow you to calculate RPM and feed rates for amy material and any bit size. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
Tool Question??? | Paul | Home Built | 2 | September 1st 03 04:06 PM |
Question on Pulsejets/Ramjets??? | DarylG1532 | Home Built | 3 | August 16th 03 03:20 AM |
Structural adhesive question | BD5ER | Home Built | 1 | August 3rd 03 06:03 AM |
Fairing question... | Tina Marie | Home Built | 5 | July 16th 03 12:18 AM |
