Noise issues with Oudie 2 in a couple different aircraft
Old July 20th 14, 09:59 PM posted to rec.aviation.soaring
2G
Default Noise issues with Oudie 2 in a couple different aircraft
On Friday, July 18, 2014 9:19:00 PM UTC-7, Doug Mueller wrote:
Is anybody else having noise issues when the Oudie is hard wired
to ships power. I know two aircraft that have the squelch turned on
to try to drown out the noise on the radio. I believe it is from the
Oudie while it is being charged. I recently added the Oudie to the
aircraft and now the radio will not cancel out after receiving a
transmission. I have tried wrapping the wiring of the oudie and the
gps cables to try andshield them but it isnt helping. After I turn off
the Oudie the radio returns to normal. Thanks, Doug
Besides adding the ferrite beads as already suggested, you should take a look at the power distribution. Ideally, all power returns (sometimes erroneously called "grounds") should come to a common single-point ground. Daisy-chaining these returns to various instruments will couple electrical noise from one to others. Have that single point connection as close to the battery as possible, with the lead going to the battery as large as practicable.
Tom
Oudie Issues vontresc Soaring 4 July 16th 14 04:44 AM
Why bother about light aircraft noise. [email protected] Piloting 36 July 13th 05 09:52 PM
Newer aircraft mx issues SAC Owning 4 July 6th 05 05:59 PM
Couple of Plugs: Stan Shannon and Wicks Aircraft Larry Smith Home Built 8 November 8th 03 01:22 AM
ISO back issues Combat Aircraft magazine mark e digby Military Aviation 0 August 12th 03 05:39 PM
