On Mon, 10 May 2004 20:16:55 +1000, John Cook
wrote: On 09 May 2004 17:00:58 GMT, (IanDTurner) wrote: Anyone know a figure as to max payload weight? It can carry 7500Kg + of weapons etc, the Max takeoff weight is 23,000Kg or more.. Cheers John Cook 23,000kg seems a bit low. The latest F-16s top out hgiher than that and they're a smaller aircraft. I guess if they say 23k then it's 23k. I'd have guessed something more like 26k or 27k, |
On Mon, 10 May 2004 05:08:51 -0600, Scott Ferrin
wrote: On Mon, 10 May 2004 20:16:55 +1000, John Cook wrote: On 09 May 2004 17:00:58 GMT, (IanDTurner) wrote: Anyone know a figure as to max payload weight? It can carry 7500Kg + of weapons etc, the Max takeoff weight is 23,000Kg or more.. Cheers John Cook 23,000kg seems a bit low. The latest F-16s top out hgiher than that and they're a smaller aircraft. I guess if they say 23k then it's 23k. I'd have guessed something more like 26k or 27k, There really funny like that, they said for years the internal fuel load was 4000Kg, turns out its 4996Kg (at least on the development aircraft), The data they usually give is sometimes a bit dated, or they could just be a bit secretive. The strange thing is the fuel loads and other parameters should be reasonally easy for an aircraft design team to work out. The other factor is the Typhoon is just entering service, it needs to complete its basic testing and evaluation first, perhaps then the overload conditions could be explored later on. Look at the Raptor, they said for ages the MTOW was 50000lbs, if you added the weights bandied around then the fuel load was a lot smaller than a few 'commentators' were estimating....... It under quoting rife from aircraft manufacturers??? Cheers John Cook Any spelling mistakes/grammatic errors are there purely to annoy. All opinions are mine, not TAFE's however much they beg me for them. Email Address :- Spam trap - please remove (trousers) to email me Eurofighter Website :- http://www.eurofighter-typhoon.co.uk |
On Mon, 10 May 2004 21:25:00 +1000, John Cook
wrote: On Mon, 10 May 2004 05:08:51 -0600, Scott Ferrin wrote: On Mon, 10 May 2004 20:16:55 +1000, John Cook wrote: On 09 May 2004 17:00:58 GMT, (IanDTurner) wrote: Anyone know a figure as to max payload weight? It can carry 7500Kg + of weapons etc, the Max takeoff weight is 23,000Kg or more.. Cheers John Cook 23,000kg seems a bit low. The latest F-16s top out hgiher than that and they're a smaller aircraft. I guess if they say 23k then it's 23k. I'd have guessed something more like 26k or 27k, There really funny like that, they said for years the internal fuel load was 4000Kg, turns out its 4996Kg (at least on the development aircraft), The data they usually give is sometimes a bit dated, or they could just be a bit secretive. The strange thing is the fuel loads and other parameters should be reasonally easy for an aircraft design team to work out. The other factor is the Typhoon is just entering service, it needs to complete its basic testing and evaluation first, perhaps then the overload conditions could be explored later on. Look at the Raptor, they said for ages the MTOW was 50000lbs, if you added the weights bandied around then the fuel load was a lot smaller than a few 'commentators' were estimating....... The 50k figure was the original ATF spec in the 80's. I think it was even before they decided on Lockheed and Northrop that they figured squeezing everything they wanted into 50k wasn't going to happen so they bumped it to 60k. ISTR that the F119s as flown in the YF-22 and YF-23 were designed for the 50k figure. GE had bumped the power of the 120 to deal with the extra weight but P&W figured they'd press on as-is. That was the reason for the 120 being more powerful than the 119 back then. Also the most common figure for the fuel load for the YF-22 was 25k. If you compare the aft fuselage of the YF-22 to the F-22A you can see they slimmed it down quite a bit. As the current figure for the internal fuel of the F-22A is 18,700lbs my guess is they lost some fuel volume when they did that. As for today's Raptor's weight who knows? I've seen 34k but it's hard to believe the F-35 is as heavy as the F-22 when the F-22 is much larger (then again I'm trying to figure out why an F-35 is as heavy as an empty Tomcat.) If you go with the F-22A having the SAME empty weight as the F-35 (34k last I heard) Then 34k + 18,700 fuel + ~2000 for the eight missiles + 200 for the pilot you get. . .about 55k. If you then add external stores you could bump that to almost 75k. |
Eurofighter weapon load mystery | John Cook | Military Aviation | 2 | January 27th 04 10:01 PM |
Shock news EUROFIGHTER to be axed in RAF program changes. | Aerophotos | Military Aviation | 11 | November 10th 03 08:55 PM |
Eurofighter is turning into German nightmare | Chad Irby | Military Aviation | 45 | October 4th 03 03:18 AM |
Eurofighter - useless in cold weather and fog? | Peter Kemp | Military Aviation | 9 | September 13th 03 04:37 AM |
Eurofighter Costs | John Cook | Military Aviation | 0 | July 9th 03 11:58 AM |
