I Just recently made some using this Template:
http://www.goddard.com/wipers/wiper1.pdf They seem to be working great. I ordered some 0.040" thick Mylar which seems to work perfect. I selected a thicker material to see if it would be more robust than what I had before. The material before was quite thin and tore in a couple places. I have about 50 hours of flying on my new wipers and they appear to be holding up quite well. I may go back and re-cut them this winter just to make them about 1/4" wider, but we will see. -SW On Tuesday, June 17, 2014 12:43:37 AM UTC-7, wrote: Hi, it would be great if anybody could send me some information on how to build these seals (templates, dimension, material, etc). Thanks, --oliver Am Sonntag, 6. Januar 2013 13:57:29 UTC+1 schrieb KiloKilo: You were flying contests in 1979? You must be one of those legacy soaring pilots ...:-) kk On Sunday, January 6, 2013 12:54:25 AM UTC-5, wrote: I owned an original LS 3 for many years. Never had a problem with the seals in flight. But the wing root brackets in the factory Komet trailer would crease them unless they were taped together in a gentle curve before lowering the lid. I think I recall adjusting the brackets in the trailer to eliminate this problem. Dick Johnson's testing indicated there was some performance loss without the seals. I know of at least one owner who used auto body putty to build up a flat spot on each side of the fuselage so the butt end of the flaps could "wipe" against them (with a felt seal) and dispense with the flexible seals entirely. I watched them perform this minor modification in the hangar on a rain day at a contest back in...1979? ![]() Chip Bearden ASW 24 "JB" U.S.A. |
On Friday, July 25, 2014 1:04:22 PM UTC-4, Sierra Whiskey wrote:
I Just recently made some using this Template: http://www.goddard.com/wipers/wiper1.pdf Here is the url for the templates along with revisions I made to the above design and pix of them installed. Regards, Zero One (Larry Goddard) |
On Saturday, July 26, 2014 9:54:35 AM UTC-4, wrote:
On Friday, July 25, 2014 1:04:22 PM UTC-4, Sierra Whiskey wrote: I Just recently made some using this Template: http://www.goddard.com/wipers/wiper1.pdf Here is the url for the templates along with revisions I made to the above design and pix of them installed. Regards, Zero One (Larry Goddard) Oops... Here's the URL === http://www.goddard.com/wipers/ |
On Friday, July 25, 2014 at 10:04:22 AM UTC-7, Sierra Whiskey wrote:
I Just recently made some using this Template: http://www.goddard.com/wipers/wiper1.pdf They seem to be working great. I ordered some 0.040" thick Mylar which seems to work perfect. I selected a thicker material to see if it would be more robust than what I had before. The material before was quite thin and tore in a couple places. I have about 50 hours of flying on my new wipers and they appear to be holding up quite well. I may go back and re-cut them this winter just to make them about 1/4" wider, but we will see. -SW On Tuesday, June 17, 2014 12:43:37 AM UTC-7, wrote: Hi, it would be great if anybody could send me some information on how to build these seals (templates, dimension, material, etc). Thanks, --oliver Am Sonntag, 6. Januar 2013 13:57:29 UTC+1 schrieb KiloKilo: You were flying contests in 1979? You must be one of those legacy soaring pilots ...:-) kk On Sunday, January 6, 2013 12:54:25 AM UTC-5, wrote: I owned an original LS 3 for many years. Never had a problem with the seals in flight. But the wing root brackets in the factory Komet trailer would crease them unless they were taped together in a gentle curve before lowering the lid. I think I recall adjusting the brackets in the trailer to eliminate this problem. Dick Johnson's testing indicated there was some performance loss without the seals. I know of at least one owner who used auto body putty to build up a flat spot on each side of the fuselage so the butt end of the flaps could "wipe" against them (with a felt seal) and dispense with the flexible seals entirely. I watched them perform this minor modification in the hangar on a rain day at a contest back in...1979? ![]() Chip Bearden ASW 24 "JB" U.S.A. RE "I ordered some 0.040" thick Mylar" DO you mean 0.004" thick (extra zero in there) Clear Polysester Film McMaster part # 8567K42 https://www.mcmaster.com/#polyester-(pet)/=1bmm306 My LS3 seals are getting a bit ratty looking too. Thanks wfpalmer at gmail |
I would really think it is supposed to be 0.040" thick, that's like a couple sheet of paper, your number is very thin.
Think of the spark gap in an automotive spark plug.Â* That's normally
around .028" to .032".Â* Some electronic ignitions call for a larger gap.Â* Borrow a set of feeler gauges or a caliper and see what .040" looks like. On 2/18/2018 6:26 PM, Charlie M. (UH & 002 owner/pilot) wrote: I would really think it is supposed to be 0.040" thick, that's like a couple sheet of paper, your number is very thin. -- Dan, 5J |
Mylar aileron and flap seals | Grider Pirate[_2_] | Soaring | 12 | June 2nd 12 01:52 AM |
Glider For Sale : Rolladen Schneider LS-7 Low time | [email protected] | Soaring | 1 | April 26th 08 09:09 PM |
Glider For Sale : Rolladen Schneider LS-7 Low time | [email protected] | Soaring | 0 | April 26th 08 08:55 PM |
For Sale: Rolladen Schneider LS-7 Low time. | [email protected] | Soaring | 1 | March 24th 08 01:45 PM |
LS-3a flap-fuselage gap seals | James D'Andrea | Soaring | 5 | May 9th 06 11:44 PM |
