iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch)
Old September 13th 14, 08:26 PM posted to rec.aviation.soaring
Sean Fidler
Default iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch)
Just wondering what the timing of the next version of iGlide which will hopefully take advantage of the new iPhone 6 form factor.
I have been using iGlide more and more and really enjoy flying with it. Its UI is BY FAR the easiest.
Thanks in advance.
Sean
7T
Old September 14th 14, 12:30 AM posted to rec.aviation.soaring
Sean Fidler
This looks interesting: http://www.air-avionics.com/air/inde...aring-avionics
Old September 14th 14, 03:19 PM posted to rec.aviation.soaring
Richard[_9_]
I have been flying with the Butterfly Vario Display S for several years and it is totally sunlight readable. It is as good as my Ultimate Le and Le57 screen. I believe the larger displays are the same technology as the Display S and will be excellent in the sun and vastly superior to the apple products. They new instruments are supposed to be available this winter.
http://www.craggyaero.com/butterfly.htm
Richard
www.craggyaero.com
Old September 14th 14, 06:01 PM posted to rec.aviation.soaring
Andy K
Who knows maybe the new instruments will support US contest rules right from the beginning.
By the way does anyone know if iGlide supports US rules?
AK
Richard
www.craggyaero.com
Old September 15th 14, 05:15 AM posted to rec.aviation.soaring
Sean Fidler
Hmmm. What instruments/computers do not support US rules? What exactly is not supported?
iGlide has been great for me with US tasks (if that's what you mean). Statute miles, feet for start and finish heights, etc. Turn areas of up to 30 mile radius (check ;-)), etc.
Old September 15th 14, 11:11 AM posted to rec.aviation.soaring
Andy K
e.g. 2 min start, MAT task
Old September 18th 14, 10:28 PM posted to rec.aviation.soaring
Craig Funston
Sean,
Were you able to integrate the vario data from your V7 with the iGlide app using Air Connect? I know it will integrate with FLARM. If iGlide doesn't integrate with a vario is it still able to accurately estimate wind since it doesn't have airspeed input?
Thanks,
Craig
Old September 22nd 14, 03:35 PM posted to rec.aviation.soaring
glidergeek
Thanks in advance.
Sean
7T
I up graded my iPad 3 to IOS8 yesterday I just have Iglide lite, lost my airspace and any maps I've downloaded but not my way-point files but I can't see them either. As of this morning I still can't down load them.
Old September 22nd 14, 05:03 PM posted to rec.aviation.soaring
noel.wade
You probably need to turn on Location Services in your iPhone system preferences. Then allow iGlide to use location services. IGlide seems to filter the available countries/maps based on your position (at least, in my testing).
--Noel
Old September 22nd 14, 05:30 PM posted to rec.aviation.soaring
glidergeek
Is on still no Joy!
36 Inch Hdtv [email protected] Piloting 0 May 17th 09 12:48 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Home Built 4 March 11th 04 11:31 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Aviation Marketplace 4 March 11th 04 11:31 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar General Aviation 4 March 11th 04 11:31 PM
3 1/8 inch compass Steve Beaver Home Built 2 October 21st 03 12:20 AM
