ClearNav Vario and XCSoar
Old December 31st 14, 12:52 AM posted to rec.aviation.soaring
Dan Marotta
Default ClearNav Vario and XCSoar
I'm trading in my CAI-302 for a ClearNav XC vario. Looking at the setup
screen in XCSoar, there's no listed driver for the CNv vario. The XCSoar
Manual also says nothing about the CNv vario though it states that it
will work with any vario which outputs NMEA data. Both my Android phone
and my Dell Streak 5 connect via bluetooth and work great.
Has anybody tried this combination yet? My new vario should arrive some
time next week...
Dan Marotta
Old December 31st 14, 01:30 AM posted to rec.aviation.soaring
Dave Leonard
On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote:
I'm trading in my CAI-302 for a ClearNav XC vario.* Looking at the
setup screen in XCSoar, there's no listed driver for the CNv vario.*
The XCSoar Manual also says nothing about the CNv vario though it
states that it will work with any vario which outputs NMEA data.*
Both my Android phone and my Dell Streak 5 connect via bluetooth and
work great.
Has anybody tried this combination yet?* My new vario should arrive
some time next week...
Dan Marotta
I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar)
Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that.
-Dave
Old December 31st 14, 02:58 PM posted to rec.aviation.soaring
work great.
Dan Marotta
-Dave
Does that apply to WinPilot (Pro) as well? Drop-in replacement? Connectivity to Avier?
Herb
Old December 31st 14, 04:01 PM posted to rec.aviation.soaring
Dan Marotta
Thanks Dave,
I spent the day yesterday with my panel at the dining room table. I
have all the wires brought out the panel hole and labeled, waiting for
the connector. Just about finished with cleaning up 13 years of wiring
modifications. I'll spend some time on the couch getting acquainted
with the new unit...
Dan
work great.
Dan Marotta
-Dave
Dan Marotta
Old December 31st 14, 04:17 PM posted to rec.aviation.soaring
Tango Eight
work great.
Dan Marotta
-Dave
Herb
Not completely (sorry).
!w (air data) and !g (bugs, ballast, Mc) are fully supported. Task entry/declaration and file d/l over serial connection are *not* supported! Attempts to put CNv in command mode will cause data transmission to stop.
best,
Evan Ludeman for CNi
Old December 31st 14, 04:39 PM posted to rec.aviation.soaring
Tango Eight
states that it will work with any vario which outputs NMEA data..*
work great.
Dan Marotta
-Dave
Herb
best,
btw, if anyone wants to discuss this further, let's take it over he
http://clearnav.net/simplemachinesfo...hp?topic=181.0
best,
Old December 31st 14, 05:04 PM posted to rec.aviation.soaring
Dan Marotta
Been trying to establish an account on the ClearNav forum. The page
says an email has been sent, but I'm not receiving it. Checking my spam
folder, too. My username has been registered so I can't go on without
that email...
work great.
Dan Marotta
-Dave
Herb
best,
best,
Dan Marotta
Old December 31st 14, 05:13 PM posted to rec.aviation.soaring
Dan Marotta
Looks like I won't have much trouble making the switch. Using my Streak
via K6BT, I've only changed bugs, ballast, and MC setting. I do use the
download flights feature with the 302 but I don't see much problem with
USB download. I'll either put a connector through the panel for that or
just dangle the extension cable out the back for use after landing. Not
concerned with contest flying or landouts.
work great.
Dan Marotta
-Dave
Herb
best,
best,
Dan Marotta
Old December 31st 14, 05:38 PM posted to rec.aviation.soaring
Dan Marotta
Figured it out. I'm registered now.
spam folder, too. My username has been registered so I can't go on
without that email...
work great.
Dan Marotta
-Dave
Herb
best,
best,
Dan Marotta
Dan Marotta
Old January 2nd 15, 11:33 PM posted to rec.aviation.soaring
cuflyer
Dan, I did the exact set up last year: 302 to CNv with XC Soar. The CNv will control XCSoar, but not vice versa. It will kill the comm like Evan stated.
Really has not been a problem, though. I'm happy.
Tim
work great.
Dan Marotta
New ClearNav CNv Vario LCD Display Paul Remde Soaring 5 June 20th 14 11:53 PM
WTB Clearnav Xcountry Vario Go Soaring Soaring 0 January 26th 14 01:29 PM
ClearNav CNv vario software update Evan Ludeman[_4_] Soaring 5 April 17th 13 12:28 AM
More Vario Questions - ClearNav SteveB_Z5 Soaring 4 June 12th 12 02:24 AM
ClearNav Vario Paul Remde Soaring 5 January 8th 11 11:34 PM
