On Tuesday, February 3, 2015 at 7:45:06 AM UTC-8, firsys wrote:
In my book, warnings for take off roll and landing approach should be audio, not on the panel. To divert your attention from outside risks a ground loop or worse. During takeoff, the only point at which I glance at the ASI is after I have three axis control. JMF At 15:12 03 February 2015, Dan Marotta wrote: Thanks Evan and Peter. If the winds are light enough to rig today, I'll try it out. Dan On 2/3/2015 3:45 AM, Peter Purdie wrote: Hi Dan In case the rather shorthand answers have still left things unclear, the system is working correctly for Gear and Spoiler Warnings active. In most ships you don't want to roll with spoilers open, so have that warning active. Spoilers open, gear down, no airspeed is a warning and SPOILERS will show on the screen. For LS8/ASW24 or whatever where you want to roll with them open until you have good roll control, disable the warning. You will still get a warning (with Gear Warning enabled) if you open spoilers with gear up. You can test the spoiler warning function is correct by pressurising pitot to 50 knots, opening the spoilers should then give no warning unless the gear is up. Peter. On Monday, February 2, 2015 at 4:11:24 PM UTC-8, Dan Marotta wrote: I finally completed installation of my new CNv XC vario and am having problems with the gear/spoiler warning logic. In my installation, while sitting on the trailer, opening the spoiler causes the Spoiler warning to flash and sound off.=A0 This happens without respect to the gear position or switch reading.=A0 Reading the switches in the Info section of the CNv, I see that bot h switches are correctly wired and functioning (both show 0 and 1 status as appropriate). Is it possible that this is a ground test function and I won't know if everything works as intended until my first takeoff? -- Dan Marotta Is what you are seeing a "spoilers open" warning (during takeoff roll) vs .. a "gear up" warning? -- Dan Marotta The best warnings are from the Butterfly Vario. The Bitching Betty will say in a loud clear voice "SPOILERS ARE OPEN". Or "LANDING GEAR NOT EXTENDED". This does not leave you glancing around the cockpit wondering if it is the engine controller, the gear, the spoilers, the PDA, FLARM the oxygen control - all of which were capable of beeping in my glider. Now only the engine control and O2 control beeps. Everything else is explained to me by the B.B. |
ClearNav Vario and XCSoar | Dan Marotta | Soaring | 9 | January 2nd 15 11:33 PM |
New ClearNav CNv Vario LCD Display | Paul Remde | Soaring | 5 | June 20th 14 11:53 PM |
WTB Clearnav Xcountry Vario | Go Soaring | Soaring | 0 | January 26th 14 01:29 PM |
More Vario Questions - ClearNav | SteveB_Z5 | Soaring | 4 | June 12th 12 02:24 AM |
ClearNav Vario | Paul Remde | Soaring | 5 | January 8th 11 11:34 PM |
