Dittel Dynamic Mic wiring
Old February 5th 15, 10:05 PM posted to rec.aviation.soaring
Default Dittel Dynamic Mic wiring
On Wednesday, February 4, 2015 at 7:45:06 PM UTC-5, Doug Mueller wrote:
Hello all, I have a dittel FSG-60M Radio in my glider. It has a mic plug
with a telex IR Electric headset. The headset is inconvenient and I got a
Dynamic Mic from Wings and wheels. The glider was hard wired with a
PTT and a separate speaker. I have removed the plug on the end of the
mic and I wish to hard wire the mic. A brown,white wire with a ground
are in the mic line. I do not have a wiring diagram for the mic. I looked
at the FSG-60M installation instructions was trying to figure out if an
amplifier is needed to run the new set up. W&W was not very helpful
and I could use some expertise as I thought it would be rather simple
to replace the mic. The radio is set up for a dynamic mic already. It is
inscribed on the outer case. I do not believe it was ever changed from
the previous owner. Anybody with experience with this set up? Thanks,
Doug
Doug, no problem.
From what I read, I didn't see which mic you're going to, thus no further info.
Pass that on (what mic you're going to), maybe one of can provide some more info.
If nothing else, this thread may come up (with similar questions/search), thus more info linked for the next person..... ;-)
Old February 5th 15, 11:05 PM posted to rec.aviation.soaring
Doug Mueller
Hi Charlie,sorry it is a Dittel F10039 Dynamic mic. It has a ground
braided wire, one white wire and one brown wire.
Doug
At 22:05 05 February 2015, Charlie M. UH & 002 owner/pilot
mic plug
I got a
wired with a
end of the
ground
looked
if an
helpful
simple
already. It is
changed from
Thanks,
Doug
Doug, no problem.
further
info.
some more
info.
questions/search),
Old February 6th 15, 10:30 PM posted to rec.aviation.soaring
Dave Springford
Hi Doug,
I am not familiar with the FSG60, but on some other radios, different pins on the harness plug are used for dynamic mics than are used for standard (or electret mics). Since you have the manual, you should check the wiring diagram to see if this is the case for the 60. If it is, that explain why it did not work when you connected it to the old jack wires. If the manual does not make this distinction, then some of the older radios have a potentiometer that you adjust with a screw driver for the gain required of a standard vs dynamic mic.
In terms of the mic itself, there should be two wires plus a ground wire. The ground is usually a shield or a bare wire. As far as the other two wires, it does not matter how they are connected as far as + -. Just like a speaker, it does not matter which direction the current flows through the mic. So, as long as you can determine the ground wire you are set.
Old February 7th 15, 01:41 AM posted to rec.aviation.soaring
Jock Proudfoot
At 22:30 06 February 2015, Dave Springford wrote:
Hi Doug,
pins
(o=
d=
i=
manual
potent=
stan=
wir=
s=
mi=
The FSG 60/ FSG 60M can be set for an amplified microphone or a dynamic
one. To select, the shorting plugs at P 3009 and P 3011 are reversed as
shown in Fig. 3-11.
See
http://ww.cumulus-soaring.com/dittel...ser_manual.pdf
P 3009 & P3011 ( Jump Connectors ) are accessable after opening the upper
cover.
Dittel FSG40S wiring connections Anthony Manwaring Soaring 3 June 23rd 14 05:42 PM
Dittel FSG 50 in Dittel base station [email protected] Soaring 2 February 18th 09 09:15 AM
Dittel FSG 50 in Dittel base station, Perfect for crews and FBO [email protected] Soaring 1 February 18th 09 09:15 AM
looking for Dittel FSG 60M wiring diagram ken ward Soaring 1 May 29th 05 02:54 AM
Dittel FSG50 wiring diagram Chris Davison Soaring 0 October 15th 03 07:23 AM
