New Cobra trailer - - which top?
Old February 11th 15, 05:14 PM posted to rec.aviation.soaring
Ben[_6_]
Default New Cobra trailer - - which top?
So, if you were ordering a new Cobra trailer, would you order a fiberglass top or an aluminum top? For sake of discussion, lets exclude obvious price difference.
I've never seen an aluminum top with insulation. What type of insulation is used and is it worth the 1000 plus euros?
For those having a reasonably new Cobra trailer, in your opinion, what options are "mandatory" and what options are "losers"?
Thanks for your feedback.
Old February 11th 15, 06:01 PM posted to rec.aviation.soaring
jfitch
The aluminum top will look better far longer. Unless you bend it - then the fiberglass top is far easier to repair.
I would question whether insulating the top will actually do any good for anything, unless you are planning on heating the interior.
Old February 11th 15, 06:09 PM posted to rec.aviation.soaring
Tony[_5_]
The only one I've seen with insulation was a very large custom built Cobra that was designed to fit a Slingsby Capstan. It now holds a Morelli M-200. The insulation is at most 1/2" thick and was glued to the inside of the trailer top. I don't think I've seen insulation in any of the other Cobra's that I've pulled.
Old February 11th 15, 06:38 PM posted to rec.aviation.soaring
On Wednesday, February 11, 2015 at 10:10:00 AM UTC-8, Tony wrote:
The only one I've seen with insulation was a very large custom built Cobra that was designed to fit a Slingsby Capstan. It now holds a Morelli M-200.. The insulation is at most 1/2" thick and was glued to the inside of the trailer top. I don't think I've seen insulation in any of the other Cobra's that I've pulled.
Forget Cobra's factory interior lights. I found them to be very "weak" at best.
Old February 11th 15, 09:08 PM posted to rec.aviation.soaring
Craig Reinholt
I've had the insulated AL top trailer for 12 years and agree with the above comments. I believe the insulation reduces sweating inside the trailer. I heat the trailer during the winter months with a chicken incubator (available at any farm hardware store). Incandescent light bulbs have been known to cause fires and this is a much safer alternative.
Al tops are a bit lighter. Reducing hail damage will probably favor fiberglass. Reducing annual maintenance will strongly favor AL tops. Aesthetics, IMO, favor the fiberglass top. Both are top quality products from Spindelberger.
Old February 11th 15, 11:26 PM posted to rec.aviation.soaring
Andrzej Kobus
I owned both AL and fiberglass. My next one is going to be fiberglass. Although my AL trailer looks close to new condition I fear if I ever get any damage it is for ever. I saw a fixed AL trailer with a bunch of rivets in wrong places. Fiberglass can always be painted after a couple of years (out gassing completed) and it will look great for a long time reducing the maintenance.
Old February 12th 15, 12:05 AM posted to rec.aviation.soaring
Ben[_6_]
Aluminum Cobras certainly have the nasty habit of "raining" on the inside due to condensation. The more humid the climate, the worse it gets.
Is the insulation just "raw" EPS board (expanded polystyrene like Dow blue styrofoam) glued to the inside? And only the roof - - not the sidewalls?
If it is just "raw" EPS board, I would think it would dent, ding, and pick easily and look awful after usual wear and tear.
Old February 12th 15, 12:36 AM posted to rec.aviation.soaring
I've only owned glass tops (3). IMHO the work to keep it looking nice makes Alum look appealing. Glass is like waxing four cars...unless it needs rubbing out, then it's like ten cars......"Wax on, right hand. Wax off, left hand. Wax on, wax off. Breathe in through nose, out the mouth. Wax on, wax off. Don't forget to breathe, very important".
Old February 12th 15, 03:33 AM posted to rec.aviation.soaring
jfitch
As Andrzej says, one thing that could be done is to wait a bit for the glass and gelcoat to settle down, then scuff and shoot the whole thing with PU. I think that would cut the maintenance by quite a lot for 10 years or so anyway. Add that to the cost of the trailer. Good PU finishes don't require waxing (and it will not extend their life in any case), just wash it once in awhile. Which costs more to begin with, FRP or ALU?
Old February 12th 15, 05:06 AM posted to rec.aviation.soaring
Darryl Ramm
Hey Whitney
I hope the lights I installed in my (then your) Cobra trailer worked better.. Just RV fluorescent tubes, and a 30Ah or so VRLA battery in the trailer. Nowadays I would use LEDs. I was very proud of that exterior mast-head (for a yatch) halogen lamp on the rear of the trailer top... It would pretty provide enough light to derig at night. I think I used it exactly twice :-)
Darryl
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
looking for used Cobra trailer Brad[_2_] Soaring 3 July 1st 11 02:58 AM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
Cobra Trailer Soaring 1 September 28th 03 01:14 PM
