On Friday, February 13, 2015 at 3:45:50 PM UTC-5, Dave Nadler wrote:
Hi All - Below is the draft I sent to Spindelberger; nothing happened since; need to chase it... Problem is two-fold: - jack the top back to square - keep it there I received instructions starting "remove the top from the trailer"... Right. I designed & sketched the kludgery to fix in situ and Alfred built the parts shown in this document. I thought they were going to sell repair kits... http://www.nadler.com/public/Cobra/C...rcement_01.pdf There are MANY different Cobra tops and the angles and dimensions of this jack-thing would be different for each. An alternative scheme would be build an external jack mechanism, straighten, then install the wee blocks as installed in the same location on newer trailers. BE CAREFUL! Hope this helps, Best Regards, Dave PS: BE CAREFUL! PPS: This worked fine on my Antares trailer (20k+ miles since without further issue). PPPS: BE CAREFUL!! Alfred also made parts for Eric Greenwell, but Eric hasn't yet installed them. I'll get photos eventually... |
Cobra Trailer front access door .... | Ron Gleason | Soaring | 6 | September 9th 14 08:55 PM |
Cobra Trailer-Replacing front panel | K | Soaring | 2 | January 15th 14 02:25 PM |
2013 Cobra trailer price list needed for TA trailer sale | [email protected] | Soaring | 0 | June 22nd 13 02:42 PM |
Cobra Trailer leak, front end gasket, fix? | SF | Soaring | 1 | December 20th 10 07:30 PM |
Nat'l Museum USAF-Assorted 11-10-06 - RB-47 lower front left NMUSAF 11-10-06.JPG (1/1) | Blue Oval | Aviation Photos | 0 | November 11th 06 02:09 AM |
