IOIO board for SN10 to Samsung Galaxy Note 4
Old May 10th 15, 03:52 PM posted to rec.aviation.soaring
Dan Marotta
Default IOIO board for SN10 to Samsung Galaxy Note 4
Yeah... But my big brother can beat up your big brother...
Each of these HW/SW systems has its advantages and disadvantages when
compared to the others. Each of us has his own concept of what works
best for him and what doesn't. Why not simply tell the pluses and
minuses of your system and not waste everyone's time by hammering all
the things you don't use? Note: This is not intended as an attack on
any one person but a comment on years of reading RAS.
On 5/10/2015 5:39 AM, waremark wrote:
Thanks for replying. I think some of that is a bit like saying the Porsche 911 is unchanged in 50 years. I always use fingers not stylus on SYM without difficulty, find zoom and pan easy, and by the way Oudie now has connectivity using bluetooth via a phone. The SYM UI works really well for frequent tasks like task entry which is slicker than XCS. Each to their own.
Dan Marotta
Old May 10th 15, 05:46 PM posted to rec.aviation.soaring
Sean Fidler
I would not want to be on the Oudie side of the debate table when debating any aspect of software, hardware or especially innovation potential. ;-). The Oudie is a cheap (and wildly overpriced), old product in my opinion. Sure, it does "work" and it does have integration solutions (Goddard cables, etc, also quite overpriced in my opinion) for most (also outdated usually) soaring electronics. What can I say, I have one too.
I still use an SN10 for example. Not the fountain of youth either but it works very well for everything except the infamous HAT task.
When it comes to affordable, innovative tech in the cockpit (once smartphones are fully allowed to shine) smartphones will be truly revolutionary for their simplicity and capability. That time is already here for non US contest flying. In fact it is quite painful to have to literally DISABLE my smartphone for a contest flight.
I agree, to each their own. I think be going a little further (building the IO board, etc) I will have a lot more fun soaring and learn a lot along the way...
Go flying!
Old May 10th 15, 07:07 PM posted to rec.aviation.soaring
waremark
"I would not want to be on the Oudie side of the debate table when debating any aspect of software, hardware or especially innovation potential."
As I said, each to their own.
Old May 11th 15, 07:31 PM posted to rec.aviation.soaring
kirk.stant
On Saturday, May 9, 2015 at 4:42:25 PM UTC-5, Sean Fidler wrote:
Thanks Robert. Great info. Soldering iron warming up...
Sean, this is EXACTLY why many of us prefer the Oudie to building a "supposedly" superior system out of more "up to date" technology and software.
Buy it, hook it up, configure the displays to your liking (or use the defaults if you are really lazy or computer-challenged) and go fly. Oudie does that, at a fraction of the cost of the higher end systems.
Myself, I'll probably stick to my SN10+Oudie2+PF setup until something significantly better is available (and I don't see XCsoar as "significantly better" than SYM, in the ways I use my moving map). Right now, what I'm watching is the evolution of iGlide and the sunlight readability of the big iPhones - when they meet my personal criteria of features and cost-effectiveness, then I might retire my Oudie. My SN10, OTOH, stays until it dies, I like it so much...
And, as a big believer in redundancy - I would never want my primary nav display to also be my retrieve phone, etc. That's just asking for Murphy to have a go!
Meanwhile, have fun with your science project and keep us posted!
Kirk
66
Old May 12th 15, 01:31 AM posted to rec.aviation.soaring
Kirk - I'm not sure I understand your point here. Are you saying that choosing to "roll our own" custom HW interface solution is a negative? If someone either doesn't have the skills or simply doesn't want the hassle then they can purchase any one of a number of pre-built cables and interface solutions that will work with XCSoar. This is no different than hooking an Oudie up to instrumentation - you can "roll you own" or buy a pre-made cable and interface kit. Maybe I missed the point...
Kirk
66
Old May 12th 15, 06:53 PM posted to rec.aviation.soaring
kirk.stant
Robert, perhaps I didn't make myself clear enough. I think it's great that you guys are putting together systems to integrate new displays with new software in interesting ways - but please go back and look at your previous post; to most of the glider owners in my club it would be totally incomprehensible! For them (and me, largely because I'm not interested in spending the time putting together a custom made system) even as simple a system as the Oudie seems too complicated. So when Sean makes long statements about how superior his custom approach is to something like the Oudie, he doesn't realize that for many, his approach is totally out of the question.
I personally like SYM because I can customize it to do exactly what I want. I'm sure XCsoar can be setup equally well, but I'm not interested in learning a whole new UI for no real performance difference. TopHat looks interesting on a Kobo mini eink tablet as a stand-alone device for club ships. I've used WinPilot (OK) and tried StePla (too "german"!); even looked at LK8000 (too many numbers that I really don't care about) - but keep coming back to SYM because I'm used to it.
iGlide looks really interesting...
Anyway - whatever a person uses is fine if it makes the soaring experience more fun and safer!
Cheers,
Kirk
66
Old May 12th 15, 11:29 PM posted to rec.aviation.soaring
LK8000 on Mio and cabled to Power Flarm and V7.
Pros: Forum support that is excellent, beautiful interface, easy task declaration to Flarm, fully utilizes pitot, barometric sensor, etc of V7/Flarm. Handles Turn area tasks and MATS easily. Simulator for PC
Cons: Requires some "hacking" of chosen device. Requires windows based platform. Only source of MIO compatable cables (my device) is glidertools. Requires home study to fully understand and configure many options
Lane
XF
Old May 13th 15, 01:42 AM posted to rec.aviation.soaring
Well, you're certainly right that my original post is generally incomprehensible to anyone who is not already familiar with an IOIO interface. But, in my defense, the post was not really meant to describe how to actually build one - its pretty clear that Sean was already experienced with it.
This gets me thinking, though, how many people may actually be interested in putting an Android XCSoar device in their cockpit, connect it to their 302 or Flarm, etc. but are afraid to do so because of a lack of very detailed instructions. I wonder if there would be much interest in an article in Soaring Magazine that shows in detail how to build and use an IOIO based solution? Anyone out there want to read such an article?
Robert
Cheers,
Kirk
66
Old May 13th 15, 02:50 AM posted to rec.aviation.soaring
Yep
Robert
I personally like SYM because I can customize it to do exactly what I want. I'm sure XCsoar can be setup equally well, but I'm not interested in learning a whole new UI for no real performance difference. TopHat looks interesting on a Kobo mini eink tablet as a stand-alone device for club ships.. I've used WinPilot (OK) and tried StePla (too "german"!); even looked at LK8000 (too many numbers that I really don't care about) - but keep coming back to SYM because I'm used to it.
Cheers,
Kirk
66
Old May 13th 15, 03:02 AM posted to rec.aviation.soaring
Absolutely!
iPhone 6+ or Galaxy Note 4? Duster Soaring 22 March 28th 17 01:23 AM
XCSoar and Top Hat issues running on Samsung Galaxy Tab 3 Gary Adams Soaring 4 July 11th 13 03:55 PM
C-5 Galaxy approaches WPAFB - C-5 Galaxy WPAFB final apch 4-17-07.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 April 18th 07 03:03 PM
C-5 Galaxy-getting in some flight time - C-5 Galaxy lft bank Dayton,OH 12-14-06.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 December 17th 06 04:41 PM
C-5 Galaxy-getting in some flight time - C-5 Galaxy rt bank Dayton,OH 12-14-06.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 December 17th 06 04:41 PM
