Ron Wanttaja wrote in message . ..
On 27 Nov 2003 00:38:04 -0800, (Paul Lee) wrote: What about the prop make/model. I have an IVO prop, which is experimental anyway. Should it also be designated AMA/EXPR - UNKNOWN? Or does that matter so much? The FAA Registration databases I downloaded don't seem to have propeller data in them. The FAA probably has a record of it, but it's not reflected in the registration files I have. Its in box 9 and 10 of the "Application for Airworthiness Certificate". Paul ------------------------------------------------- SQ2000 canard project: www.abri.com/sq2000 |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Hi-performance endorsment with a experimental engine | Paul Lee | Home Built | 15 | September 11th 03 12:00 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
