13.5 Meter World Championships
Old July 29th 15, 06:49 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
Default 13.5 Meter World Championships
My ideal glider would be something with Discus performance & FES.
Many of the pilots in my club fly Discus / LS4 performance gliders, or
lower performance club class.
The GP14 claims to have mid 40s performance, as does the original Discus.
If there was a FES option I'd seriously consider it.
The problem with the PW5 was it had no performance & was ugly as sin.
KN
At 15:07 29 July 2015, Gliding Guru wrote:
Why would anyone spend money on a 13.5 glider? Big mistake of the IGC t
permit the class. Even bigger mistake of the Manufacturers to buil
something for it. Glorified PW5's and we all know how that ended!
Old July 30th 15, 09:27 PM posted to rec.aviation.soaring
KN
Why have a FES in a GP14 when you could have the retractable electric self-launcher version - and forego the extra drag and ugliness of the prop moustache?
Old July 30th 15, 10:57 PM posted to rec.aviation.soaring
Al McNamara
prop
moustache?
Speed of starting.
Old July 30th 15, 11:31 PM posted to rec.aviation.soaring
son_of_flubber
prop
moustache?
Speed of starting.
Looking forward to someone using FES recover to recover from a premature termination of tow.
Old July 31st 15, 12:00 AM posted to rec.aviation.soaring
Renny[_2_]
prop
moustache?
Speed of starting.
Well, I've had my Lak17B FES for almost 4 years and fortunately I have never had a premature termination of tow, but I always have it ready to go during a tow should it be needed. On several occasions I have used it instead of having to land for a relight. It does reliably start within a second or two and there is no mast to extend which definitely saves time. Now, I have seen a video of an auto launch on the FES website where a LAK 17a is able to climb away after dropping the rope at perhaps 200(?) feet, so I do believe it can safely be done as long as there is sufficient altitude. What exactly would be "sufficient" altitude depends on many factors and I am sure could be the subject of a very interesting discussion....Thx - Renny
Old July 31st 15, 12:02 AM posted to rec.aviation.soaring
prop
moustache?
Speed of starting.
I will assume we will see a "broken glider w/FES" from a PTT if they're NOT FLYING THE GLIDER.
Sorta like the guy (decades ago) that had a PTT (at a "famous site in the US") call his wife and say, "I'm going to crash!", just before he crashed.
I guess the "aviate" bit was lost on them.......
Old July 31st 15, 12:08 AM posted to rec.aviation.soaring
Renny[_2_]
On Thursday, July 30, 2015 at 5:02:46 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
prop
moustache?
Speed of starting.
Hopefully, one can actually aviate and rotate one FES switch at the same time....
Old July 31st 15, 01:31 AM posted to rec.aviation.soaring
son_of_flubber
Drop nose, turn on FES (I guess).
Have you practiced this in your Lak17B? Do you have to worry about running into the tow plane or do you turn slightly to the right?
Old July 31st 15, 02:14 PM posted to rec.aviation.soaring
prop
moustache?
Speed of starting.
But speed of starting is irrelevant for self launching and for self-retrieving speed of starting is a tiny factor compared with probability of starting which, for any with well designed and maintained electric powered glider, will be a near certainty.
Old August 1st 15, 03:30 PM posted to rec.aviation.soaring
Sean Fidler
Website on the GP14. One of the best websites I have seen for a glider manufacturer. Good sign!
http://www.gpgliders.com/gp-14-velo-0
World Gliding Championships. R. Suppards Soaring 0 July 6th 14 11:03 AM
Women’s World Gliding Championships RRK Soaring 2 June 19th 11 01:17 PM
5th Junior World Gliding Championships [email protected] Soaring 0 July 28th 07 11:43 AM
World championships in Sweden CD Soaring 0 June 5th 06 11:03 PM
