fiberglass repair?
Old August 10th 15, 12:55 AM posted to rec.aviation.soaring
Bill T
Default fiberglass repair?
I'm not a fiberglass expert. But a through and through cut needs to be repaired properly just like an impact that would have cracked the hull.
Directions are in the maintenance manual, to include scarfing to widen the repair area, laying in epoxy, cloth, etc. Sanding and refinishing.
A simple repair, not done properly, could crack and get longer as the fuselage flexes in turbulence and with temperature changes.
BillT
Old August 10th 15, 02:29 AM posted to rec.aviation.soaring
I respectfully suggest that someone who cuts through the fuselage in an attempt to repair a batter tray should not be repairing the fuselage.
Just a thought.
Old August 10th 15, 02:31 AM posted to rec.aviation.soaring
Lots of people have done it jackass. Ask around. It ain't that uncommon
Old August 10th 15, 03:37 PM posted to rec.aviation.soaring
Eric Munk
And don't forget the correct curing temperatures of the repair. Cutting
corners there significantly reduces strength in the affected area.
Old August 10th 15, 07:50 PM posted to rec.aviation.soaring
BillT
What is the context of this thread?
UH
Fiberglass glider repair in Southern California? Roger Worden[_2_] Soaring 4 September 2nd 12 02:37 AM
this guy doesn't believe in fiberglass rwhughe Aviation Photos 0 February 27th 10 06:05 AM
Fiberglass revisited Lou Home Built 3 October 31st 06 12:50 PM
Fiberglass seperation Lou Home Built 7 September 25th 06 04:03 AM
Fiberglass/gelcoat repair question Kilo Charlie Soaring 9 April 19th 05 03:30 PM
