In message , Alan Minyard
writes On 31 May 2004 16:01:19 GMT, Alistair Gunn wrote: [1] Though I believe they was a successful engagement with Sea Dart against a target at 50 feet? [2] Though, IRIC, the Type 42s (and HMS Bristol) where never deployed into San Carlos Water. I have often wondered why the Brits did not use manpads. Were they unavailable? Blowpipe was used in respectable numbers, though it was more effective against Pucaras than fast-movers. The SAS had some Stingers, which were also used. -- He thinks too much: such men are dangerous. Julius Caesar I:2 Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
![]() "Alan Minyard" wrote in message ... On 31 May 2004 16:01:19 GMT, Alistair Gunn wrote: I have often wondered why the Brits did not use manpads. Were they unavailable? They did, the Short Blowpipe to be precise, there were not as good as the current generation of manpad's but still managed to shoot down a number of the Argentine aircraft, mainly the Pucara's operating in the CAS role IRC. Keith. |
WalterM140 wrote:
Reduce that dud rate to zero and the whole Brit expeditionary force becomes POWs. You could equally say reduce the dud rate to zero and the odds are good the FAA doesn't have any a/c left, because most of them have been shot down. The reason so few bombs detonated is because the FAA pilots had the normal instinct for self-preservation, and usually flew as low and fast as they could to make the job of the defenses much harder. But this meant that bombs were often dropped from altitudes too low to allow sufficient time for fuse operation, so many of the bombs dudded, or the fuse delays were so long (to allow time for the wingmen to clear the target before the bombs exploded) that bombs which weren't stopped by structure inside the ship passed on through and out the other side before exploding. The whole reason for the defenses was to make the pilots more worried about survival than destroying their targets, thus increasing the incident of duds. CTG 317.0 (the amphibious shipping), Commodore Clapp, was very glad that the Argentine pilots were chosing to make level bomb runs instead of pop-up dive attacks, for just that reason. Well, that's interesting, but it seems to indicate that the Brits were gambling they could induce the Argintines to attack incorrectly. Not very prudent. It wasn't a gamble at all, it was planned that way. Clapp had been a Buccaneer observer and squadron commander, and he chose San Carlos Water for the landings and set up the ships and land defenses to provide the Argentine pilots with just that dilemma. The layout of the defenses was optimised to hit pilots making pop-up dive attacks; British missiles would have been more effective as well, not being bothered as much by ground clutter, and there would have been less worry about having to check fire to avoid shooting up friendly troops/ships on the other side of the water. As it was, the Argentine pilots chose to come in very low and fast, limiting their acquisition time and the effectiveness of their attacks, but improving their survival rate. Looked at objectively, they should have accepted the higher losses of dive attacks for the potentially higher gains, but then that's easy to say from the comfort of my chair. You seem to agree that if -all- the bombs had detonated the Brit supporting force would have been reduced below a level where the invasion could have been supported. Doubtful. Most of the bombs hit the escorts outside of San Carlos Water; some were effectively knocked out of the war in any case, even though they weren't sunk. Only two LSLs were hit by bombs in SCW, Sir Lancelot and Sir Galahad, and the amount of damage caused if they'd gone off would have depended on where they hit and what they were carrying at the time. If all the bombs had gone off then it's possible that the British government might have decided that the cost was too high, and it would almost certainly have delayed the ground forces. But they had lots of reinforcing ships on the way, most of which arrived when the war was over or nearly so, so their stores/equipment weren't needed. Argentina had no such second wave capability. And Fuerza Aerea target priorities on D-Day sucked, which was ultimately a far bigger problem than the dud bombs. Hitting the escorts didn't delay the land campaign; hitting more of the supply ships before they could unload would have. Assuming that they'd ever been hit, the loss of Fearless would have caused a major delay as she was the amphibious command ship, but her sister Intrepid could have taken over, albeit at lower efficiency. Other than that, the Brits would have had to lose a carrier; everything else (other than lives) was replaceable. As an example, losing Atlantic Conveyor and the Chinook/Wessex helos she was bringing down was the single most important blow to the campaign that the British suffered, but her sister Atlantic Causeway arrived less than a week later, bringing another 28 or so helos with her (Wessex/Sea King). Another two ships were coming south bringing more Chinooks and other helos, and arrived right about the time of the surrender. Guy |
gambling they could induce the Argintines to attack incorrectly. Not very prudent. It wasn't a gamble at all, it was planned that way. Clapp had been a Buccaneer observer and squadron commander, and he chose San Carlos Water for the landings and set up the ships and land defenses to provide the Argentine pilots with just that dilemma. The layout of the defenses was optimised to hit pilots making pop-up dive attacks; British missiles would have been more effective as well, not being bothered as much by ground clutter, and there would have been less worry about having to check fire to avoid shooting up friendly troops/ships on the other side of the water. As it was, the Argentine pilots chose to come in very low and fast, limiting their acquisition time and the effectiveness of their attacks, but improving their survival rate. Looked at objectively, they should have accepted the higher losses of dive attacks for the potentially higher gains, but then that's easy to say from the comfort of my chair. You seem to agree that if -all- the bombs had detonated the Brit supporting force would have been reduced below a level where the invasion could have been supported. Doubtful. Most of the bombs hit the escorts outside of San Carlos Water; some were effectively knocked out of the war in any case, even though they weren't sunk. Only two LSLs were hit by bombs in SCW, Sir Lancelot and Sir Galahad, and the amount of damage caused if they'd gone off would have depended on where they hit and what they were carrying at the time. If all the bombs had gone off then it's possible that the British government might have decided that the cost was too high, and it would almost certainly have delayed the ground forces. But they had lots of reinforcing ships on the way, most of which arrived when the war was over or nearly so, so their stores/equipment weren't needed. Argentina had no such second wave capability. And Fuerza Aerea target priorities on D-Day sucked, which was ultimately a far bigger problem than the dud bombs. Hitting the escorts didn't delay the land campaign; hitting more of the supply ships before they could unload would have. Assuming that they'd ever been hit, the loss of Fearless would have caused a major delay as she was the amphibious command ship, but her sister Intrepid could have taken over, albeit at lower efficiency. Other than that, the Brits would have had to lose a carrier; everything else (other than lives) was replaceable. As an example, losing Atlantic Conveyor and the Chinook/Wessex helos she was bringing down was the single most important blow to the campaign that the British suffered, but her sister Atlantic Causeway arrived less than a week later, bringing another 28 or so helos with her (Wessex/Sea King). Another two ships were coming south bringing more Chinooks and other helos, and arrived right about the time of the surrender. Guy Sounds like good info. Thanks, Walt |
Army ends 20-year helicopter program | Garrison Hilliard | Military Aviation | 12 | February 27th 04 07:48 PM |
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) | Matt Wiser | Military Aviation | 0 | December 7th 03 08:20 PM |
French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 06:48 PM |
Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 08:05 AM |
