Keith Willshaw wrote:
"Ian" wrote in message ... Is it still the case that the USN uses the trailing drogue (as the RAF/RN do), with the USAF using the tanker to steer the probe? If so, why the different approaches? The flying boom method has a higher transfer rate but probe and drogue can be fitted to buddy tankers. Right. Originally (1950s) SAC used the boom method, while TAC used probe and drogue on their fighters (KB-50P? tankers), starting with F-84s. There were air-refueled test combat missions flown during the Korean War using KB-29 tankers; the F-84s couldn't be given airframe mounted probes in a hurry, so were given drop (tip) tanks fitted with a probe on the front (a method that has recently been revived to allow F-16s to refuel from drogue-equipped tankers). There was no internal transfer possible, so the procedure was to refuel one drop tank to about half full, disconnect, reposition for the other tank and fill it full, then disconnect and reposition on the original tank and fill it the rest of the way. Filling one tank completely first resulted in too much lateral assymetry for the ailerons to compensate. F-100s, F-104Cs and EB-66s all had probes. At the end of the 1950s SAC and TAC were both operating versions of the F-101, so that a/c was given both types of refueling capability (and had the room). The F-105B had the probe, but the D model was eventually given both methods. After that the USAF decided to go over completely to the boom/receptacle method, as their tankers would (presumably) always have airbases to operate from, just as their fighters and bombers would. The boom gives better transfer rates and seems to be more reliable and easier to tank from, but it does limit the types of a/c that can be tankers, and it requires a lot more money and work to convert. Guy |
Guy Alcala wrote:
After that the USAF decided to go over completely to the boom/receptacle method, as their tankers would (presumably) always have airbases to operate from, just as their fighters and bombers would. The boom gives better transfer rates and seems to be more reliable and easier to tank from, but it does limit the types of a/c that can be tankers, and it requires a lot more money and work to convert. Will the F-35B be the first USAF aircraft since then to be built with just a probe? -HJC |
![]() "Henry J Cobb" wrote in message ... Guy Alcala wrote: After that the USAF decided to go over completely to the boom/receptacle method, as their tankers would (presumably) always have airbases to operate from, just as their fighters and bombers would. The boom gives better transfer rates and seems to be more reliable and easier to tank from, but it does limit the types of a/c that can be tankers, and it requires a lot more money and work to convert. Will the F-35B be the first USAF aircraft since then to be built with just a probe? Clearly USAF helicopters have been built with "just a probe". Outside of the rotory wings I can't think of any USAF probe refuelers during the last 30 some years. |
On Wed, 2 Jun 2004 01:00:49 -0400, "John Keeney"
wrote: "Henry J Cobb" wrote in message ... Guy Alcala wrote: After that the USAF decided to go over completely to the boom/receptacle method, as their tankers would (presumably) always have airbases to operate from, just as their fighters and bombers would. The boom gives better transfer rates and seems to be more reliable and easier to tank from, but it does limit the types of a/c that can be tankers, and it requires a lot more money and work to convert. Will the F-35B be the first USAF aircraft since then to be built with just a probe? Clearly USAF helicopters have been built with "just a probe". Outside of the rotory wings I can't think of any USAF probe refuelers during the last 30 some years. A-7D? |
Buzzer writes: On Wed, 2 Jun 2004 01:00:49 -0400, "John Keeney" wrote: "Henry J Cobb" wrote in message ... Guy Alcala wrote: After that the USAF decided to go over completely to the boom/receptacle method, as their tankers would (presumably) always have airbases to operate from, just as their fighters and bombers would. The boom gives better transfer rates and seems to be more reliable and easier to tank from, but it does limit the types of a/c that can be tankers, and it requires a lot more money and work to convert. Will the F-35B be the first USAF aircraft since then to be built with just a probe? Clearly USAF helicopters have been built with "just a probe". Outside of the rotory wings I can't think of any USAF probe refuelers during the last 30 some years. A-7D? Nope. The Air Force's A-7s had a slipway & boom socket on the upper fuselage. The only non-helicopter probe-only USAF airplane I can thig of, post 1960, was the A-37. I wouldn't doubt that if teh USAF were to take on an F-35B flavor, that it would have a boom recepticle fitted. It's not a hard thing to do, and it doesn't take up much space. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
John Keeney wrote:
Clearly USAF helicopters have been built with "just a probe". Outside of the rotory wings I can't think of any USAF probe refuelers during the last 30 some years. How many helicopter capable tankers does the USAF have? Or do they have to call in the Marines? ;-) -HJC |
Henry J Cobb writes: John Keeney wrote: Clearly USAF helicopters have been built with "just a probe". Outside of the rotory wings I can't think of any USAF probe refuelers during the last 30 some years. How many helicopter capable tankers does the USAF have? Somewhere around 95 - all the HC-130s and MC-130s have been set up for it. Or do they have to call in the Marines? ;-) The USAF actually has more than the marines. The USMC's got 75 KC-130s - many of those are set up for refuelling fixed-wing aircraft. That requires a different hosereel & drogue. One more, Henry typed before gaining even the most basic understanding of his subject. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
![]() "Peter Stickney" wrote in message ... In article , Henry J Cobb writes: John Keeney wrote: Clearly USAF helicopters have been built with "just a probe". Outside of the rotory wings I can't think of any USAF probe refuelers during the last 30 some years. How many helicopter capable tankers does the USAF have? Somewhere around 95 - all the HC-130s and MC-130s have been set up for it. Or do they have to call in the Marines? ;-) The USAF actually has more than the marines. The USMC's got 75 KC-130s - many of those are set up for refuelling fixed-wing aircraft. That requires a different hosereel & drogue. One more, Henry typed before gaining even the most basic understanding of his subject. Don't tell me you are surprised by that...? :-) Brooks -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
![]() "Henry J Cobb" wrote in message ... John Keeney wrote: Clearly USAF helicopters have been built with "just a probe". Outside of the rotory wings I can't think of any USAF probe refuelers during the last 30 some years. How many helicopter capable tankers does the USAF have? Or do they have to call in the Marines? ;-) Never heard of the old HC-130? Now renamed MC-130P, IIRC? Brooks -HJC |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Enola Gay: Burnt flesh and other magnificent technological achievements | me | Military Aviation | 146 | January 15th 04 10:13 PM |
EADS aims at USAF tanker market | Matt Wiser | Military Aviation | 0 | September 20th 03 05:54 PM |
FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 08:32 PM |
