On Wednesday, October 21, 2015 at 10:08:37 AM UTC-4, Dan Marotta wrote:
"Another option is to look for something like a used Cambridge 302 that will be much cheaper and give you many of the same features." Except for the Bluetooth connectivity.* You would either have to build or buy a serial to Bluetooth converter to use the CAI-302 to interface to a PDA.* I used such a setup for over 3 years and was very happy with it. Dan - 5J Can the 302 be hard wired to a PDA? |
That depends on the PDA. Some may accept a direct connection but the
output of the 302 is RS-232 in the input to the PDA is generally USB. You'll need a level converter. The Dell Streak 5 that I use requires some interface converter. I use a K6BT serial to bluetooth converter (it worked on my 302 and, with a different cable it now works with my ClearNav vario). I know someone else who has a wired connection to his Streak using a IOIO device. I understand you can buy them complete or buy the parts and build your own. Lately I've seen very inexpensive serial to Bluetooth devices. Here's an example http://www.amazon.com/KEDSUM%C2%AE-Arduino-Wireless-Bluetooth-Transceiver/dp/B0093XAV4U. On 10/21/2015 3:25 PM, wrote: On Wednesday, October 21, 2015 at 10:08:37 AM UTC-4, Dan Marotta wrote: "Another option is to look for something like a used Cambridge 302 that will be much cheaper and give you many of the same features." Except for the Bluetooth connectivity. You would either have to build or buy a serial to Bluetooth converter to use the CAI-302 to interface to a PDA. I used such a setup for over 3 years and was very happy with it. Dan - 5J Can the 302 be hard wired to a PDA? -- Dan, 5J |
20B Panel | jcarlyle | Soaring | 21 | April 1st 09 10:57 PM |
IFR PANEL | Flyhighdave | Home Built | 4 | January 18th 05 04:24 AM |
IFR PANEL | Flyhighdave | Home Built | 4 | January 17th 05 07:15 PM |
Panel restoration | Roger Halstead | Restoration | 0 | September 3rd 04 05:46 AM |
182 panel | Jim | Owning | 2 | August 2nd 03 09:06 PM |
