On Wednesday, December 16, 2015 at 10:27:17 PM UTC-5, Six-Seven Romeo wrote:
I am installing a used Becker AR3201 transceiver for a friend. It didn't come with a harness. I can make the harness myself and could use a standard DB-15 connector. However, I would prefer to use the latching type connector that Becker specifies and you can see on the AR4201 and AR6201 (which use a DB-25 instead of the needed DB-15). Does anyone know of a source for the DB-15 latching connector? Thanks, John Latching? Like threaded fasteners? Look at electronics places online like Digikey or Newark Electronics. They have screws, studs, standoff's (short piece with a male thread on one end and a female thread on the other end). Shipping will likely be more than the part. If you have a PC repair place near you, they may also have them. |
@Charlie M. This isn't a very common type of secure connection for D connectors that use a screen. There is a slide as part of the radio's male D connector that engages "studs" on the cable's female D connector.
All - I found that both Dittel and Becker use the same latching mechanism and Cumulus-Soaring.com has the Dittel version of the female D connector. |
Wow. That got messed up. Lets try again.
================= @Charlie M. This isn't the very common simple screw type of secure connection for D connectors. On the Becker radios there is a slide as part of the radio's male D connector that engages "studs" on the cable's female D connector. All - I found that both Dittel and Becker use the same latching mechanism and Cumulus-Soaring.com has the Dittel version of the female D connector. |
On Thursday, December 17, 2015 at 12:04:35 PM UTC-5, Six-Seven Romeo wrote:
Wow. That got messed up. Lets try again. ================= @Charlie M. This isn't the very common simple screw type of secure connection for D connectors. On the Becker radios there is a slide as part of the radio's male D connector that engages "studs" on the cable's female D connector. All - I found that both Dittel and Becker use the same latching mechanism and Cumulus-Soaring.com has the Dittel version of the female D connector. Fair enough, just trying to say I have bought quite a few "D-type capturing devices" that can be sourced through the 2 listed sources. Without seeing it, I can only guess. Was only hoping it was a source to you. ;-) |
At 17:04 17 December 2015, Six-Seven Romeo wrote:
Wow. That got messed up. Lets try again. ================= @Charlie M. This isn't the very common simple screw type of secure connection for D connectors. On the Becker radios there is a slide as part of the radio's male D connector that engages "studs" on the cable's female D connector. All - I found that both Dittel and Becker use the same latching mechanism and Cumulus-Soaring.com has the Dittel version of the female D connector. I have seen this type of latching connector quite often in ex military radio sets, however this is in the UK, it may be worth checking any military surplus stores to see what you can find. Ben. |
What you looking for is a lock lever and locking tabs that are available from Positronic. Catalogue available at http://www.connectpositronic.com/?media_dl=2293 , page 28.
These usually require that Positronic backshell is also used. They are excellent connectors. There are many distributors. Robert On Thursday, December 17, 2015 at 9:04:35 AM UTC-8, Six-Seven Romeo wrote: Wow. That got messed up. Lets try again. ================= @Charlie M. This isn't the very common simple screw type of secure connection for D connectors. On the Becker radios there is a slide as part of the radio's male D connector that engages "studs" on the cable's female D connector. All - I found that both Dittel and Becker use the same latching mechanism and Cumulus-Soaring.com has the Dittel version of the female D connector. |
Becker AR3201 Radio need help | [email protected] | Soaring | 4 | July 31st 14 03:06 AM |
Becker AR3201 | Lazarost | Soaring | 3 | March 26th 13 06:16 AM |
Becker AR3201 | [email protected] | Soaring | 4 | April 6th 09 11:15 PM |
Wanted: Becker AR3201 | Ira Blieden | Soaring | 0 | December 14th 06 06:28 PM |
Looking for a Becker AR3201 | Ira Blieden | Soaring | 0 | December 8th 06 01:38 PM |
