Case Study Near Mid Air Glider and C421 - Benefits of PowerFlarm and Transponders
Old January 20th 16, 11:40 PM posted to rec.aviation.soaring
Dan Marotta
Default Case Study Near Mid Air Glider and C421 - Benefits of PowerFlarmand Transponders
That was very good watching, Walt. I wonder why the ATC controller did
not give the 421 a slight turn rather than simply issuing a warning of a
conflict. This also shows that it's not a bad idea to monitor Approach
and Departure frequencies when you're in or near standard routes. Glad
there was nothing more than some unnecessary excitement!
On 1/20/2016 12:09 AM, WaltWX wrote:
With all the discussion about FLARM, ADS-B and the Pros/Cons, I thought the time is right to bring some facts into the discussion. Last September I had a near mid air with a C421. Since I had recently equipped over the previous winter with a Mode S transponder (Trig T22), I was curious whether: 1) It was working... 2)Did the FAA use my target to call traffic.
Turned out the answer was yes! to both questions. I filed a near mid report to the FAA which resulted in two interviews and this radar ARTCC video with ATC controller audio. I think you'll find it quite interesting.
https://dl.dropbox.com/s/k8ph9wogyif...1 TT.wmv?dl=0
The FAA statement incorrectly identified the twin as a King Air with only (my visual esimate)
horizontal separation estimate of 500ft.
https://dl.dropbox.com/s/e6gvhn6dybx...FAA.pdf?dl =0
According to the radar we passed by at 10,000msl zero vertical and 1300ft horizontal. By pure luck and good scanning technique, I sighted the C421 15 seconds before crossing. PowerFlarm PCAS went off 2-3 seconds later. PowerFlarm would have got my attention if my visual scanning had failed me. No evasive action occurred on my part.
When you listen to the audio/video you will see a red "CA" meaning Conflict Alert going off for the controller. This went off at 33 seconds. If FAA modified their ADS-B ERAM software, they could send out ADS-B packets for aircraft on a collision course. PowerFlarm would then have given plenty of warning without cluttering the bandwidth of ADS-B with unnecessary information. This recommendation was made to the FSDO FAA representative who interviewed me.
I am complete agreement with Darryl Ramm's analysis of this whole transponder (Mode S) PowerFlarm recommendation. They complement each other quite well... and this is the best solution for the time being. As he has said, the whole ADS-B thing with TABS looming in the near future is in a state of flux. I wouldn't be surprised to see combined Mode-S/ADS-B transponders coming onto the market in abundance within 3 or 4 years.
In case you are wondering ... I did NOT recommend in my response to the FAA NPRM immediately equipage of gliders with transponders. Instead, utilize good airspace practices, training and a short "wait and see" for more affordable equipment to become available. However, if you have the money... by all means equip with a transponder and PowerFlarm.
Walter Rogers "WX" Discus 2A
Dan, 5J
Old January 21st 16, 01:10 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Well there are good controllers and not so good. I have had many very close calls, while flying under flight following, IFR plan, or under the Tower's control. Four of my nearest (one within inches) happened within several hundred or less feet of actually taking off, and still over the runway. Burbank, Santa Barbra (twice), and El Cajon. The one in Burbank also involved an United Airlines MD80, in Santa Barbra the control tower actually was ****ed off at the C414 pilot that loudly complained he had to take sudden low altitude evasive manouvers (we both did!) and go around because the control tower had directed me (departing in a helicopter) nose to nose with the C414 on short final. To this day I can hear the controller with a very annoyed tone, "yeah just go around, cleared to land..."
Another time flying a C340 through the Owens valley on flight following, Joshua approach in a harried/worried tone informed me that two F/A-18's were converging on my position from behind, then he asked if I had the traffic. Told him I did not have much rear visibility. He then told me in a worried tone "they are approaching fast!" I asked him for a course to deviated, it was like he had never thought of that! I do not include this as a near miss, I have had so many. Some you cannot control like the AS---le that flew underneath me (i could see him via Mode S traffic display on my HSI/map/traffic instrument) and as he dove to go under I turned 90 degrees only to see him zoom up where I had been. I think this fool was trying to fly under me then scare me by zooming up from underneath, however, had I not turned, he would have hit me as he did not have vision above. I am in full support of anything that gives me the most situational awareness as possible!
Perhaps a better use of Flarm resources rather than to develop a stealth mode would be to certify the Flarm GPS for use with trig and garrecht transponders that have ADS-B out and then output the data so our computers will display all traffic from any acronym source. I already have three GPS' I am hoping I will not have to buy a fourth to get ADS-B.
On Wednesday, January 20, 2016 at 3:40:47 PM UTC-8, Dan Marotta wrote:
That was very good watching, Walt.* I wonder why the ATC controller
did not give the 421 a slight turn rather than simply issuing a
warning of a conflict.* This also shows that it's not a bad idea to
monitor Approach and Departure frequencies when you're in or near
standard routes.* Glad there was nothing more than some unnecessary
excitement!
Dan, 5J
Old January 21st 16, 04:01 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Wednesday, January 20, 2016 at 5:10:06 PM UTC-8, Jonathan St. Cloud wrote:
Another time flying a C340 through the Owens valley on flight following, Joshua approach in a harried/worried tone informed me that two F/A-18's were converging on my position from behind, then he asked if I had the traffic.. Told him I did not have much rear visibility. He then told me in a worried tone "they are approaching fast!" I asked him for a course to deviated, it was like he had never thought of that! I do not include this as a near miss, I have had so many. Some you cannot control like the AS---le that flew underneath me (i could see him via Mode S traffic display on my HSI/map/traffic instrument) and as he dove to go under I turned 90 degrees only to see him zoom up where I had been. I think this fool was trying to fly under me then scare me by zooming up from underneath, however, had I not turned, he would have hit me as he did not have vision above. I am in full support of anything that gives me the most situational awareness as possible!
excitement!
Dan, 5J
Flarm only outputs NMEA over a serial port. What does a Mode S Transponder with ADS-B Out capability look for as an input for GPS? I don't think the physical or logical interfaces are compatible are they? Also - the Flarm GPS is an off the shelf consumer unit so it is not clear to me that it would ever be able to be certified and may not even qualify for TABS.
I'm mostly asking (waiting for Darryl...)
9B
Old January 21st 16, 04:18 AM posted to rec.aviation.soaring
Darryl Ramm
excitement!
Dan, 5J
9B
For a TSO GPS source you can't do it over NMEA. You can do TABS Class B over NMEA. Pretty sure I've been over this before, sigh, many times. At this point its just a memory retention/IQ test.
Look FLARM is just not ever going to produce a TSO- or "meets TSO" or even TABS spec GPS device... that would be effectively be a lot of work just for the tiny USA market. Even something as simple as TABS requires a manufacture used to dealing with TSO approval, engineering and paperwork teams, GPS constellation testers, folks to write test suites,... not the stuff that a small nimble company like FLARM which plays in the unregulated electronics space is ever likely to do, or anybody in the glider community should be asking them to do. And yes I now some parts of their OEMs do play in this space, but the economics and hassle required is just awful. Bad bad waste of their resources. All this stuff will likely come from GPS vendors used to doing this regulatory approval dance. If I heard rumors of FLARM wanting to do even TABS certification, I'd be banging on them pointing out how that is likely a lot of work and a bad business decision. I like for good companies doing good stuff to make smart decisions and be around in future.
Old January 21st 16, 04:58 AM posted to rec.aviation.soaring
Darryl Ramm
Oh and on TABS. We have no relevant installation or use regulations *at all* yet do we? So getting too worried about any of that stuff now is kinda premature. It may work out that there is no way this can be done in practice and actually installed in a glider even if FLARM wanted to.
I know just waiting and seeing must be *SO* hard...
excitement!
According to the radar we passed by at 10,000msl zero vertical and 1300ft horizontal. By pure luck and good scanning technique, I sighted the C421 15 seconds before crossing. PowerFlarm PCAS went off 2-3 seconds later.. PowerFlarm would have got my attention if my visual scanning had failed me. No evasive action occurred on my part.
In case you are wondering ... I did NOT recommend in my response to the FAA NPRM immediately equipage of gliders with transponders. Instead, utilize good airspace practices, training and a short "wait and see" for more affordable equipment to become available. However, if you have the money.... by all means equip with a transponder and PowerFlarm.
Dan, 5J
9B
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFlarm and transponders while towing? bumper[_4_] Soaring 21 February 27th 12 01:29 AM
PowerFlarm response to transponders Mark Soaring 1 November 1st 10 03:07 PM
Recent C421 crash is related to Cory Lidle jbskies Piloting 5 December 5th 06 01:48 PM
Operating cost: C421 PA31 an BE58 Jarema Owning 3 January 13th 05 12:17 PM
