On Monday, February 1, 2016 at 5:15:04 PM UTC-5, George Haeh wrote:
Flying a CG hook my hand is always on the release during tow. One of my hot button issues cockpit management issues... Touching release, okay. Grasping release... not so much. Big gust, pilot bumps head, flinches, releases inadvertently. http://tinyurl.com/gm7mwms For gliders like Ventus a/b and ASW-19&20 with release behind stick, make a loop of parachute cord, tie to release knob, lay across left leg. Easy to get to, less likely to cause problems. best, Evan Ludeman |
there are two kinds of CFIs: one kind evaluates your overall skill and safety, and the other kind thinks they can make you into a new pilot in an hour's flight. the first kind are not a problem. the second kind need to be appeased.
On Monday, February 1, 2016 at 11:43:07 AM UTC-5, son_of_flubber wrote: On Monday, February 1, 2016 at 10:08:52 AM UTC-5, Bob Pasker wrote: good catch I should have said that I was "less interested in performing the maneuver the way I was taught and the way I did it on my checkride, than I am in pleasing the CFI" I question your deference to the CFI. I'd be much more interested in practicing the maneuver the way I always practiced the maneuver (yaw slightly away from the slack). Removing slack is something that I do without thinking about it and if I had the opportunity to practice with 'deliberate slack rope', I'd profit by reinforcing my 'muscle memory'. Learning the CFI's unfamiliar way of removing slack is counter-productive, especially if it means risking the possibility of a second loop from doing something improperly. What is the point? So it seems best to resolve on the ground what techniques I'm going to use in the air. If the CFI wants me to do it differently, then he'd have to convince me that the way I was taught to do something was dangerous. If he were inflexible and insisted on doing things his way, I might opt out of getting in the glider with him. If we can't get along on the ground, then I should not fly with him. I've flown with many CFIs. I'm grateful to all of them. Only one was rigid, inflexible, and unable to carry on a conversation that deviated from his shop worn script. In retrospect, I should have opted out of flying with him. |
On Monday, February 1, 2016 at 10:43:07 AM UTC-6, son_of_flubber wrote:
On Monday, February 1, 2016 at 10:08:52 AM UTC-5, Bob Pasker wrote: good catch I should have said that I was "less interested in performing the maneuver the way I was taught and the way I did it on my checkride, than I am in pleasing the CFI" I question your deference to the CFI. I'd be much more interested in practicing the maneuver the way I always practiced the maneuver (yaw slightly away from the slack). Removing slack is something that I do without thinking about it and if I had the opportunity to practice with 'deliberate slack rope', I'd profit by reinforcing my 'muscle memory'. Learning the CFI's unfamiliar way of removing slack is counter-productive, especially if it means risking the possibility of a second loop from doing something improperly. What is the point? So it seems best to resolve on the ground what techniques I'm going to use in the air. If the CFI wants me to do it differently, then he'd have to convince me that the way I was taught to do something was dangerous. If he were inflexible and insisted on doing things his way, I might opt out of getting in the glider with him. If we can't get along on the ground, then I should not fly with him. I've flown with many CFIs. I'm grateful to all of them. Only one was rigid, inflexible, and unable to carry on a conversation that deviated from his shop worn script. In retrospect, I should have opted out of flying with him. Great advice! |
A long, long time ago I did some instructing for a club at a major university in the Boston area. Part of the checkout flight with them included a slack rope demo.
The check pilot described it and then performed it: climb up above normal high tow position, then dive on the towplane and move out to one side until a big loop of slack forms (in this case, it disappeared behind and under the wing, although we were well out to the side by then). To recover, hold position out to the side and allow the speed to bleed off; watch for the loop to reappear; and then dive slightly and turn in behind the towplane to match the speed as the slack comes out. The check pilot's attempt was "OK", although eye opening when I watched the amount of loose rope go back behind the glider and the reappear some seconds later. "Now you try it." So I did. With about the same modest success. It wasn't a smooth synchronization of speed with the towplane but we didn't break the rope. "OK, uh, that's good enough." It turned out that the local designated examiner, an experienced glider pilot, required this maneuver, which I never encountered again. Years later I recall reading about a fatal training accident in the area, the details about which were sketchy but that seemed to resonate unhappily with that day. It remains one of those experiences that I'm sort of glad I had but which I would never intentionally repeat or ask anyone else to. Chip Bearden |
Rope Break | Walt Connelly | Soaring | 4 | April 12th 11 09:04 PM |
tow rope | tazman | Soaring | 9 | August 25th 10 02:30 AM |
Slack line with water | Ron Ogden | Soaring | 10 | May 5th 09 05:55 PM |
OK you slack bastards | Glenn[_2_] | Aviation Photos | 5 | July 6th 08 02:49 PM |
11 on a Rope | Peter Seddon | Rotorcraft | 0 | May 27th 04 11:33 AM |
