Double Release Failure on Tow
Old March 28th 16, 03:46 AM posted to rec.aviation.soaring
George Haeh
Default Double Release Failure on Tow
A vigorous "Can Not
Release" signal has a
good probability of
breaking the weak link.
If you remember not to
release after breaking
the weak link, you can
use the Tost rings again.
Old March 28th 16, 04:06 AM posted to rec.aviation.soaring
JS
On Sunday, March 27, 2016 at 8:00:08 PM UTC-7, George Haeh wrote:
A vigorous "Can Not
good probability of
But landing on tow is fun.
Old March 28th 16, 05:21 AM posted to rec.aviation.soaring
[email protected][_1_]
Not this again! Yer gonna die!
Seriously, after signals are exhanged, and within a very conservative glide of the field (like overhead) open the brakes, fly normal high tow position and wheel land. Use brakes sparingly to only keep the rope taught and not run over it. The odds of a tug being able to stop more rapidly than a glider are small, short of the tug ground looping or other wreckery.
L.O.T. used to be a pre-solo confidence building maneuver employed liberally at Skylark North, CA. An instructor demo touch-and-go followed by a student touch-and-go and then a full stop by the student. Very rare that the student needed anything other than some verbal coaching.
Oh, and what JS said, much fun, and the student confidence index soared!
Double release failure = statistical nonevent. Kind of like glider-glider midairs in the USA. Maybe we need auto-LOT technology coupled to our FLARM's in case we have a potential traffic conflict while LOT-ing?
But yer gonna die..... but probably not doing LOT's or in a glider-glider midair.
Old March 28th 16, 12:37 PM posted to rec.aviation.soaring
Jonathan St. Cloud
When I did double release failure practice, we used the low tow position, fear on the high two was we would over run/fly the tow plane.
Old March 29th 16, 04:31 AM posted to rec.aviation.soaring
Bill T
The FAA Glider Pilots Handbook recommends low tow position.
BillT
Old March 28th 16, 01:05 PM posted to rec.aviation.soaring
Piet Barber
Hmmm. Could 3 touch-and-go-on-tows be good enough for a 61.56 (nee biennial) flight review?
Old March 29th 16, 01:13 AM posted to rec.aviation.soaring
AS
Used that method to get current again for the 90 day rule. I couldn't find any reference saying that these had to be full-stop landings.
Just coordinate it well with the tow pilot and let him know, that he cannot pull the power as he normally would do after the glider releases, if you are flying anything more slippery than a 2-33 or the tow plane becomes really big outside your canopy really fast!
Uli
Tost release failure Bill D Soaring 24 August 20th 13 10:49 AM
TOST Release Failure - Two Uncommanded Release's [email protected] Soaring 11 October 13th 12 10:23 AM
Double Release Failure ZZ Soaring 35 September 11th 09 03:29 AM
Double tow [email protected] Soaring 2 October 25th 05 07:16 PM
Double Tow Doug LS4 Soaring 5 October 11th 05 02:37 AM
