On Wednesday, August 3, 2016 at 3:26:11 PM UTC-7, Craig Funston wrote:
On Wednesday, August 3, 2016 at 2:07:11 PM UTC-7, Dan Marotta wrote: My Stemme came equipped with a Dynon D10a and I love it! It's so much easier to read indicated airspeed and altitude on the digital displays plus there tape indications of airspeed and altitude, clock, stall warning, and probably many other features which I just haven't looked at yet. I still use my 57mm airspeed indicator, but the little altimeter is a pain to read. On 8/3/2016 8:47 AM, Google, Dynon and probably others are offering low-cost instruments such as this one for the Experimental market: https://buy.garmin.com/en-US/US/prod514383.html Since the G5 includes attitude information it would be illegal under current rules to take it to a glider contest, but... What we have here in a very compact 3 1/8" space is all the flight data you need including airspeed, altitude, heading information, vertical speed and slip/skid. The built-in GPS will indicate ground speed and of course you have attitude info. I wonder if this would satisfy regulations as a stand-alone basic instrument. You would only have to add a vario, flight computer, radio and transponder (PFlarm integrated in moving map) for a very compact panel. Redundant altitude info would come from the vario/gsp which also today often displays airspeed if so desired. With back-up batteries, what could go wrong? Herb -- Dan, 5J Garmin lists the G5 as a Primary Flight Instrument. For experimental gliders without specific equipment lists it should be fine to replace the steam gauges (at least that's the way I'm reading Part 23 regs). It may well be more complicated than that & I'd definitely want the battery backup. It's a pretty attractive option, especially having the AHRS. Craig 7Q Craig, The LXNAV S100 has all the features of the Garmin , including an AHRS, in addition IGC approved flight recorder, speed to fly vario, simple navigation tasking and GOTO turnpoints. I fly with an S8 the smaller version. PowerFlarm-S8-Ultimate Le. I also use it for my altimeter. Richard www.craggyaero.com |
On Wednesday, August 3, 2016 at 4:24:57 PM UTC-7, Richard wrote:
On Wednesday, August 3, 2016 at 3:26:11 PM UTC-7, Craig Funston wrote: On Wednesday, August 3, 2016 at 2:07:11 PM UTC-7, Dan Marotta wrote: My Stemme came equipped with a Dynon D10a and I love it! It's so much easier to read indicated airspeed and altitude on the digital displays plus there tape indications of airspeed and altitude, clock, stall warning, and probably many other features which I just haven't looked at yet. I still use my 57mm airspeed indicator, but the little altimeter is a pain to read. On 8/3/2016 8:47 AM, Google, Dynon and probably others are offering low-cost instruments such as this one for the Experimental market: https://buy.garmin.com/en-US/US/prod514383.html Since the G5 includes attitude information it would be illegal under current rules to take it to a glider contest, but... What we have here in a very compact 3 1/8" space is all the flight data you need including airspeed, altitude, heading information, vertical speed and slip/skid. The built-in GPS will indicate ground speed and of course you have attitude info. I wonder if this would satisfy regulations as a stand-alone basic instrument. You would only have to add a vario, flight computer, radio and transponder (PFlarm integrated in moving map) for a very compact panel. Redundant altitude info would come from the vario/gsp which also today often displays airspeed if so desired. With back-up batteries, what could go wrong? Herb -- Dan, 5J Garmin lists the G5 as a Primary Flight Instrument. For experimental gliders without specific equipment lists it should be fine to replace the steam gauges (at least that's the way I'm reading Part 23 regs). It may well be more complicated than that & I'd definitely want the battery backup. It's a pretty attractive option, especially having the AHRS. Craig 7Q Craig, The LXNAV S100 has all the features of the Garmin , including an AHRS, in addition IGC approved flight recorder, speed to fly vario, simple navigation tasking and GOTO turnpoints. I fly with an S8 the smaller version. PowerFlarm-S8-Ultimate Le. I also use it for my altimeter. Richard www.craggyaero.com Thanks Richard. The S100 does look like a better option a sailplane panel. Craig |
Glider EFIS anyone? | [email protected] | Soaring | 40 | August 17th 16 04:17 PM |
EFIS Wars.... | Andy | Home Built | 10 | August 19th 06 04:18 AM |
EFIS | [email protected] | Soaring | 6 | November 15th 05 11:00 AM |
EFIS | faadpe | Soaring | 2 | November 15th 05 05:28 AM |
EFIS one for sale | nametab | Aviation Marketplace | 0 | March 3rd 04 11:31 PM |
