I've had a similar problem from time to time with my FSG-50, every now and then a burst of noise. Eventually I realized it was only happening in the circuit for runway 25 at my home base, at about 2/3 of the way on the downwind leg. It hasn't happened this year so all I can thin of is that there may have been some equipment at the storage and construction yard beneath the downwind that was putting out electromagnetic interference. This happened with the original avionic setup (Peschges VP-4E Nav), when I added a Colibri logger and with my current setup (LX8080 Simple, V5 vario, Powerflarm Core and FLarmview 57) so the rest of the equipment doesn't seem to be a factor.
The radio is pretty sensitive - I've been at 2,000ft. ASL (1,900ft. AGL) on a mountain ridge in Hope and have been able to hear transmissions from people in the circuit at Delta Airpark (both airports are assigned the same frequency) 70Km away! I tried JJ's progressive start up of the avionics with the radio squelch turned off and was pleasantly surprised to find that the noise didn't increase noticeably as I turned on the other units. |
On Thursday, October 6, 2016 at 8:41:04 PM UTC+3, wrote:
I've had a similar problem from time to time with my FSG-50, every now and then a burst of noise. Eventually I realized it was only happening in the circuit for runway 25 at my home base, at about 2/3 of the way on the downwind leg. It hasn't happened this year so all I can thin of is that there may have been some equipment at the storage and construction yard beneath the downwind that was putting out electromagnetic interference. Sometime in 1990 or 1991 I noticed that when I was speaking on the phone in my new flat in Newlands, Wellington there would sometimes be a "bzzzt" audible every four or five seconds. It seemed to happen more on rainy days. One day I was gazing out the window while on the phone (the clouds can't have been all that low, or the rain heavy) This is something like the view. I was in the brick house on the left. https://goo.gl/maps/r5WKiyG2RRA2 I noticed the bzzzt was happening in synchronization with the rotation of the big FO primary radar on Hawkins Hill 13.6 km away! |
Dittel FSG71 Radio / Squelch Questions | Bastoune | Soaring | 15 | June 12th 18 04:20 PM |
Dittel FSG 60M....Where is the internal Squelch adjustment pot? | vtcyclist | Soaring | 1 | September 20th 16 01:28 AM |
Radio manual or squelch setting question - UNIMOR RADIOCOM RS 6112 | Dan Daly[_2_] | Soaring | 0 | July 16th 15 01:22 AM |
Dittel FSG-50 Adjustable Squelch Modification | Jim Vincent | Soaring | 2 | April 13th 11 08:45 PM |
Static/Squelch Noise in Radio | Kensandyeggo | Home Built | 2 | April 13th 06 09:00 PM |
