Dittel FSG71 Radio / Squelch Questions
Old January 14th 13, 02:29 AM posted to rec.aviation.soaring
Bastoune
Default Dittel FSG71 Radio / Squelch Questions
All,
My radio (Dittel FSG 71) Squelch seems to be a bit sensitive (but by design, cannot be adjusted by the pilot). In my case, when flying, the squelch is a bit sensitive and the “white noise” of the radio comes on at times, even when there are no communications received. I can always reset the Squelch by pressing and releasing the PPT button. The radio then goes silent for a while until a real transmission is received, or until the sensitive squelch problem reappears. I cannot reproduce the problem on the ground.
I have noticed that the problem gets worse when I connect my PCAS MRX to the 12V bus of the aircraft. The problem is not as bad when I run the PCAS off AA batteries. I have also a vario+pda connected to the same 12V battery bus.
- Can the Dittel FSG71 squelch be adjusted internally? (it can not be done externally via a knob)
- If my other equipment connected on the 12V creates noise, can I install a capacitor between the power leads going into the radio to reduce the noise?
- What else could be the source of this nuissance?
Bastoune
Note: I have another radio related question but will post it separatly.
Dittel FSG-50 Adjustable Squelch Modification Jim Vincent Soaring 2 April 13th 11 09:45 PM
Dittel Radio [email protected] Soaring 11 January 27th 09 10:09 PM
Static/Squelch Noise in Radio Kensandyeggo Home Built 2 April 13th 06 10:00 PM
Radio "Squelch-type" Noise Kensandyeggo Owning 7 April 12th 06 08:20 PM
Dittel radio Q ken ward Soaring 1 October 8th 03 08:23 AM
